Old 08-10-2003, 12:08 PM
Brandon Brandon is offline
Rep: 10 Posts: 20
Adding steps to a small inflatable
Hello I currently own a 9'9" Quicksilver inflatable with an inflatable keel, I have been running a 15hp motor on it and it runs really well when there is a bit of texture on the water surface, however; when the surface is glassy it feels as if the boat slows and the motor runs harder...it almost seems as if there is some suction (which there very well could be) slowing the boat.
I have been daydreaming about making some stepped running pads that glue to the running surfaces of the pontoons and possibly the center of the hull in an effort to prevent this suction on smooth water as well as provide a faster ride all around.
It seems that the boat normally runs at about 20-25mph (guess), I am wondering if this would possibly do the trick to aerate the underside of the hull and eliminate that suction drag.
Thank you,
Brandon
Old 08-10-2003, 09:18 PM
Willallison's Avatar
Rep: 2283 Posts: 3,468
Because the bottom of the boat is not rigid, when you go faster the bottom of the boat develops a 'hook' in it. This will be particularly bad if the bottom isn't taught. Make sure that the tubes and in particular the keel are inflated as hard as you can get them. (Careful about leaving the boat out in the sun like this...)
If the bottom still isn't taught you can try adding a couple of wedges between the bottom and the transom (inside) to tighten things up.
Zodiac produced an inflatable some years back with smaller tubes located where the main tubes and bottom meet. This could be worth a try if you have access to someone who clould make them for you....
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 08-11-2003, 03:34 PM
Rep: 10 Posts: 20
Thanks a lot for your reply Will, and I will take your advice; however, I am also wondering if would be a waste of time to try and aerate the underside of this shallow draft hull with a few small steps similar to those found on some ski boats, I beleive that one particular company calls them LFIs (Laminar flow interruptors). Despite the relatively low operational speeds (20-30mph) it seems that getting the geometric bondary layer to separate and turn turbulent would still be beneficial and possibly provide a higher top end and better range. I have seen gemini inflatables produce some roll up inflatables with "highjacker tubes" attached to lift the hull out of the water at running speeds--it seems that it would benefit these small craft if the highjacker tubes were stepped somehow. Any thoughts?
Thanks, I really appreciate yours (or anybodies) interest,
Brandon
Old 08-11-2003, 07:23 PM
There are those on this forum with far greater knowledge about steps than I, but I wouldn't have thought that at the speeds you're talking about any great benefit would be derived from their addition. But more to the point, unless you can ensure that the bottom surfaces remain straight - without developing a hook - than the addition of the steps would be a complete waste of time.
Will
www.imaginocean.net
Old 08-11-2003, 08:56 PM
Sealion's Avatar
Sealion Sealion is offline
Glue Sniffer
Rep: 29 Posts: 24
I used to operate inflatable boats for the army. Although they had a stiff wooden keel below the floorboards, they also had another board hinged on the centerline, called the butterfly board situated in the last few feet before the transom underneath the keel to keep the flexible hull rigid. It was made of thin ply with the hinge made from the same material as the tubes. I could make and fit some highjacker tubes for you but unless they were big enough to lift your soggy bottom out of the water I doubt they would solve the problem, and you may have to get a longer legged motor or cut the transom down.
Nick Gilbertson
Sealion Inflatable Boats
Inflatable boat restoration... Hard Rock Boatbuilding 29 04-05-2005 01:23 AM
Small dinghy joebobb Boat Design 4 02-26-2005 03:42 PM
Small Boat Program Coordinator needed CDBarry Services & Employment 0 02-10-2005 11:31 AM
Small Power Cat Design small cat Boat Design 21 08-26-2004 04:53 PM
SNAME Small Craft CD CDBarry Education 0 02-15-2004 06:06 PM
