Old 07-07-2011, 02:54 PM
Team AJ Team AJ is offline
Rep: 10 Posts: 2
Adding stability to a sail sportsboat
Hi,
I want to modify my sportsboat so it can be sailed shorthanded. The boat has a carbon keel fin with a leed bulb. The boat weight is 900kg including the bulb with weight aprox 300kg. I want a ballast ratio around 50%. The question is: Make a new and heavyer bulb, or add length to the fin?
What do you think?
Old 07-08-2011, 01:13 PM
messabout messabout is online now
Rep: 749 Posts: 1,314
Increasing the ballast ratio by adding weight to the bulb may violate the design lines of the hull. Lengthening the fin will increase righting moment at the expense of deeper draft. Deeper draft will demand that you select your water with care. At 900kg it would seem that your boat might depend on shifting crew weight.
If you want to sail single handed, simply reduce sail and/or shorten the mast height. If the boat is from a competant designer, do not mess with the underwater appendages. Depending on how you figure ratios, you already have 50% ballast. The bulb at 300kg and the all up weight of 900kg means that the hull and rig is 600kg. 300/600=0.50 or 50%. Shorten sail, have fun single handing.
Old 07-08-2011, 01:24 PM
Rep: 10 Posts: 2
Thanks for the reply. The draft is no problem. I can increase the draft by 0.5m without any problems. The question is how much this would increase the righting moment? And what will it do to the sailing performance?
Old 07-08-2011, 08:28 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
You will also increase the stress on the hull and keel if you make them longer, both the righting moment and the stress on the keep and hull would go up directly proportional to the length of the keel. Add 50 percent more length and you add 50 percent more righting moment, and stress on the hull and fin. Unless you have good guidance on doing it I would not. Either reduce the sail area or mast height as suggested, or just add ballast to the bilge for single handing. You can always remove it easy if you want to add crew.
Old 07-08-2011, 08:55 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,591
Consider this: Quant 28-foil assist keelboat / DSS
Hugh Welbourn could help you determine how to go about it within the parameters of your boat. You might not have to beef up anything if the foil
is designed specifically to allow shorthanded sailing.
-You could also consider adding "plug-in"(removable) carbon racks to allow you to sit further outboard.
-Both these options could be designed to work with the existing structure by not exceeding the righting moment(RM) of the boat with the full crew. Neither would add much weight and both could be removed when fully crewed and either one or both would add performance because RM would be the same as with less weight. Either one or both would have to be carefully designed to work well.....
pix-Quant 28 with racks and DSS-click on image:
Adding stability to a sail sportsboat-quant-28-well.-dss-2.jpg  Adding stability to a sail sportsboat-quant-28-well-3.jpg
yes, it is a revolution
Old 07-09-2011, 02:00 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
A heavier bulb or a deeper keel doesn't improve stability much before you heel quite a lot.
I think 100kg or so of movable ballast would be better.
Maybe you need some batteries anyway? Why not move them from side to side with a simple rope arrangement?
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 07-09-2011, 04:09 PM
PAR PAR is online now
Rep: 3125 Posts: 9,397
I think adding additional ballast on the end of the fin, will test the breaking strength of every fitting in the rig in puffy or gusty conditions. Knowing that most sport boat tolerances are fairly tight, this is a very likely situation.
Your butt is the best ballast you have, so as has been mentioned shorten sail or drive partly stalled to keep her on her feet when over pressed. Optionally you can consider a bigger feed bag and put on some 40 pounds of extra, adjustable ballast.
Old 07-09-2011, 07:47 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
What do you think?
Making the keel longer isn't going to change your ballast ratio. Where did the 50% number come from anyway?
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Adding amas for stability? soffi Multihulls 8 08-23-2010 09:16 PM
Adding sail & maintaining the CE balance! ecflyer Boat Design 15 09-12-2009 07:27 AM
Adding sail and maintaining the CE balance ecflyer Sailboats 3 09-09-2009 02:46 AM
OK.........take a deep breath (adding sail to houseboat?) GOTTABSOMEWHERE Boat Design 23 07-13-2009 10:44 AM
Classic styled sportsboat Matt Lingley Sailboats 2 09-17-2006 11:10 AM
