Old 08-01-2008, 06:25 AM
aviatorm35 aviatorm35 is offline
Adding small outriggers to semi-displacement V-hull?
I have been pondering whether there is any value to adding small "outriggers" or pontoons to the aft of my 30' semi-displacement V-hull. My thoughts are:
1) This would make the boat get up on plane faster
2) Make the boat more stable and ride better in choppy waters?
3) Make the boat more fuel efficient?
4) Eliminate need for stern mounted Trim elevators?
Any thoughts from the Naval Engineering or Salty Dog crowd? Also, can you point me to anyone who has done this, sells outriggers or can design this application? If this is a dumb idea, feel free to "Say So".
***Originally posted in "Stability" forum w/ no response
Adding small outriggers to semi-displacement V-hull?-ex_img_0538.jpg  Adding small outriggers to semi-displacement V-hull?-ex_volvo-d3-160-technical-description.jpg  Adding small outriggers to semi-displacement V-hull?-ex_img_1716.jpg
Last edited by aviatorm35 : 08-01-2008 at 09:41 AM. Reason: Adding pictures and tech info
Old 08-01-2008, 06:34 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
Can you post pictures of the hull and give us more details so we know more about it?
Kenneth Grome
Old 08-01-2008, 10:56 AM
Rep: 287 Posts: 719
Thanks for adding the pictures.
In my opinion you're wasting your time to consider outriggers on a boat like this. Do you have any pictures of the bottom of the boat? Is it a deep vee hull?
Edit: Never mind, I read your attached .doc file and that's exactly what it is -- a high-speed deep vee planing hull, not a semi-displacement hull as you described it in your first post. These hulls never feel stable or handle well at anything but planing speeds. If you want a good handling boat for speeds in the 10-20 mph range you'd be better off selling this one and getting a boat that's designed for semi-displacement speeds.
Kenneth Grome
one vs. two outriggers for small canoe Anau Multihulls 2 04-21-2006 08:31 PM
Increasing speed w/ semi-displacement hull 67-LS1 Boat Design 17 12-11-2005 11:32 AM
Full Displacement of semi tdamico Boat Design 51 02-18-2004 10:42 AM
Semi-planing vs semi-displacement WayGray Boat Design 5 05-28-2003 11:21 AM
