Old 06-10-2012, 02:10 AM
Cat2Fold's Avatar
Cat2Fold Cat2Fold is offline
Rep: 13 Posts: 26
Adding padeye to freestanding carbon mast
I'm trying to add a spinnaker halyard close to the top of my mast.
It is a 38' long carbon fiber tapered tube. The base is about 8" diameter with about a 1/2" wall. The top tapers to about 3-4", unknown wall thickness (sorry for the inaccurate measurements, boat is in Mexico).
I was looking at padeyes to mount up there, and I was reading about mounting the padeye to a piece of g10 board and wrapping the g10 board with carbon tape around the mast and...
Couldn't I just Use something like this drilled through the entire mast up near the top?
http://www.westmarine.com/webapp/wcs...4#.T9Q5fWt5mSM
Seems like it'd be easier and should work.
What do you all think?
Thanks!
Brian
Old 06-10-2012, 02:41 AM
bertho bertho is offline
bertho
Rep: 45 Posts: 161
Hi,
did you check if any possibility to use a short dynema/spectra loop or belting strap to avoid any drilling/riveting on the carbon?
can you access to the inside by the top of the mast ?
cheer's
bertho
www.fusionschooner.blogspot.com
creating and building simple boat is much more difficult than complicated ones.....
Old 06-10-2012, 05:36 AM
Stumble Stumble is offline
Rep: 670 Posts: 1,308
I am always hesitant about drilling anything into CF. I have never gotten a good answer about it, but best practice seems to be to avoid holes, unless they were designed in.
That being said, stainless and CF is also something to be avoided. CF is galvanicaly active, which is one of the reasons titanium parts have become so desirable. Since titanium is significantly more noble than stainless it helps to control electrolysis.
Greg Rubin
Salesman - Allied Titanium
http://www.alliedtitanium.com/produc...dc_Results.php
Old 06-10-2012, 01:02 PM
Yacht Designer/Builder
Rep: 3465 Posts: 11,674
Yep, I'd look closely at a Spectra gasket or lashing.
PAR Plans
PAR Blog - fresh updates
Old 06-10-2012, 01:13 PM
Cat2Fold's Avatar
Rep: 13 Posts: 26
Thanks guys,
I'm not sure about access from the top of the mast. I'd assume so since the main halyard enters the mast in the front of the mast goes around a block that is through bolted inside the mast and exits the rear of the mast.
I like the idea of some sort of lashing. It could be directly under the main halyard block, but how does one get it to stay put and not spin around the mast?
I am wanting this halyard to raise and fly a fulrling drifter/genoa.
From what I understand the luff rope needs to be pretty damn tight.
Would the downward pressure pulling on the spectra lashing (of sorts)wedge it against the tapering mast and keep it in its place?
Any pics of anyone running a similar set-up?
Thanks again for all the help...
Big B
PS-I can probably find some pics of the top of my mast (or close) and post if that may help...
Old 06-10-2012, 02:56 PM
Cat,
I would find out the manufacturer of the mast and call them for guidance. Drilling into a carbon spar is just a bad idea, and a spectraloup around the mast, hoping the compression will keep it in place is a really bad idea. There are all types of shock loads, abrasion from the line, concerns about the block smacking the mast, ect that would need to be figured out.
The manufacturer should be able to give some guidance on the best place to add an internal halyard, and how to go about it without damaging the structual integrit of the spar.
Greg Rubin
Old 06-10-2012, 04:22 PM
sean9c sean9c is offline
Rep: 35 Posts: 278
Do you know if your CF mast was designed to be strong enough to take the load the spinnaker will add?
Old 06-10-2012, 09:32 PM
Originally Posted by Stumble View Post
. . . a spectraloup around the mast, hoping the compression will keep it in place is a really bad idea . . .
I disagree, a simple rolling hitch will remain in place without moving, but this is a temporary solution. Gluing a lashing or sized gasket in place would fix its location for sure, though removal and replacement would require some work. Spectra and similar lines are replacing rigging metal wholesale on a lot of boats. Stretch isn't really an issue, strength and abrasion issues can also be easily addressed.
PAR Plans
Old 06-10-2012, 09:41 PM
bntii's Avatar
bntii bntii is offline
Rep: 1324 Posts: 793
Maybe give these guys a shout and see if they have some ideals:
http://www.colligomarine.com/
Old 06-11-2012, 09:41 AM
Cat2Fold's Avatar
Rep: 13 Posts: 26
Wow, I never even thought of using a rolling hitch. I assume I'd just tie on a turning block to the tail end?
I like it. I am looking for cheap and easy to try out this used drifter I got. I can permanently afix the block when the boat eventually makes its way to my shop. As far as the mast strength goes... I do not know what it is engineered for, but I have flown a different spinnaker from the main halyard with no problems, the drifter will be for when the winds are light, and I'm pretty confident about the size and wall thickness of my masts being totally bomber. So, I'm not too worried about that...
Can a Spectra (Dyneema) line hold a rolling hitch? It won't just slip?
I see that Colligo Marine has endless dyneema loops. They have a 3" and a 4" diameter. I imagine one of those would work well if I new the exact diameter of my mast tops that are 1400 miles away from me...
Old 06-11-2012, 02:09 PM
Rep: 35 Posts: 278
Looked at your site, really cool boat
Old 06-11-2012, 02:22 PM
Of course it will hold Par, I was thinking of a permanent solution.
Cat2Fold,
Dyneema Loups are really easy to make. Like it takes two minutes to make them easy. The ones from Colligio are very well done, but there is no reason to not just spend some time working with dyneema and a splicing fid to learn how, that way you can remake them to any size you need as you go.
Take a look at the long splice at http://www.keepitsoaring.com/LKSC/Do...ing-manual.pdf you may need to shorten the bury depending on how large a loup you need, so I always recommend you throw in a lock stitch right at the crossover. But I still wouldn't consider this a long term solution. It might work to see how the boat sails with the new kite, but the wear on the mast from this would be pretty nasty over time.
Greg Rubin
Old 06-11-2012, 02:29 PM
Cat2Fold's Avatar
Rep: 13 Posts: 26
Thanks Sean... Yup I'm very fond of her.
For others...
http://cat2fold.wordpress.com
Adding a Luff Groove to Carbon Mast BobBill Sailboats 13 05-04-2012 08:22 AM
Downwind lift possible with a non-rotating freestanding mast? folotp Sailboats 3 01-04-2012 08:07 PM
rotating freestanding wing mast section and mast bend Timothy Sailboats 6 06-25-2010 12:53 PM
bearings for freestanding rotating mast Timothy Sailboats 2 08-11-2009 03:52 PM
is it possible to have a freestanding mast on a open 60"? yoshi Boat Design 8 03-18-2005 11:49 AM
