Old 12-10-2002, 12:50 PM
adding a 40 gal tank for gasoline
I have a 25 feet boat, and I find that it construction is based on ribs each at about 36 inches .
I purchased a TODD plastic fuel tank * v bottom belly type that is 52 inches long, x 26 inch wide, and 10 inch hight, which I plan to install about in the middle toward the rear of boat
My question is :
Can I cut one rib to tank shape to fit it, as distance from existing ribs are 36 inches.
Each rib is wood solid that has about t 12 inch high at V center, and are about 1 inch thick.
Is there any dange about weekening the structure and put in dange the boat???
Can someone advise me for a proper methodology to solve this problem.
please email to: apinzon@vibran.com.co
Old 12-10-2002, 05:51 PM
Rep: 1397 Posts: 7,215
It would be necessary to see the boat or the blueprints to answer you question. I assume that you have insuficient headroom to install the tank. Frames 36" on center and 12" deep sound odd. What is the material and dimensions of the hull?
Old 12-10-2002, 10:14 PM
Alvaro Pinzon Alvaro Pinzon is offline
Rep: 10 Posts: 2
I have made a posible design, inwhich I decide to add a new flow (in blue color, and placing the new tank (gray color) below driver seat and driving console as in picture
yellow is piping for control and hydraulic steering.
I will move an existing 15 galon tank (red), and place it yust below the wind shield plane, cutting floor to size of tank, in this way I don't harm any structural beam.
In this way I think, now I have a better stability of weight , as boat is today, is light, and in rough waters it jumps quite hard.
boat is in Fiberglass, local design.
I was initiaslly planning to place tank, yust in front of driving console under the floor, but I send you my new design, as I think placing it below the floor is risky, as a main rib must be cut, do you see any problem with my new design, as in drawing.
Dimensions are very close.
Old 12-10-2002, 11:40 PM
plymouth plymouth is offline
Rep: 10 Posts: 14
as in drawing
What drawing? Did you mean to post an attachment?
Old 12-11-2002, 09:39 AM
Rep: 10 Posts: 2
This is drawing pasted on a word page
epoxy fuel tanks Boatbuilding 24 08-14-2008 04:36 AM
Fuel tank inquiries. Hou-Chap Fiberglass and Composite Boat Building 5 03-04-2005 09:02 AM
Help with Replacing the Belly Tank in a 25' 72 Sea Ray Bugmanx Boat Design 9 07-24-2004 10:00 AM
gas tank building bushbunny Boatbuilding 12 11-14-2003 11:04 AM
