http://www.allpar.com/model/patriot.html It actually got to the project car stage then they looked at what would happen in an accident. I do not want to be anywhere near a 80k rpm flywheel when it comes apart...
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 02-07-2008 at 05:44 PM. Reason: typo |
| I do not want to be anywhere near a 80k rpm flywheel when it comes apart... EXACTLY the reason the "fuel crisis" is not answered by cars with flywheels. Either induction thru the vacum housing or a shaft from below could spin the unit back to full speed in under a min. Compare recharging a bat set , or resupplying high pressure air , and its far easier to meter and do for the std driver. BUT in a crash that energy of 10 or 15 gal of fuel will be in the flywheel (about 300 miles of energy) and will somehow need to be controlled. If NOT, The Liars for Hire would have a field day! FF |
| Flywheels Quote:
| I never said it was a copy, just pointed out that the idea and technology wasn't new and that there were demo vehicles, and my statement still stands. I've seen what happens when a 25 lb normal flywheel failed at 8,000 rpm. A failure in one twice as heavy (and with a larger radius of gyration) at 80,000 rpm would not be nice, even if it is in a shatter blanket.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| The A S S in ASSUME Quote:
AND it's going to be used in front of thousands of people on cars hitting upwards of 200 mph. |
| F1 My money says you have no clue how anal F1 designers are about weight. |
Edit: actually the KERS unit itself only adds 15kg to the minimum weight of the car when you include existing engine/transmission weight reductions to be implemented. Total weight of the car remains the same by fuel reduction.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 02-08-2008 at 06:57 PM. Reason: had it right the first time |
| I never said people were smart. If fact, I expect that 50 % of the people I interact with will be of below average intelligence. You do not, and will not, find me sitting in motorsport racing grandstands.
#25
| Dumbasses GOOD. The fewer pseudointellectual self-important elitists sitting in the grandstands the easier it'll be for everyone else to have fun. |
#26
The over hyped motorsports like F1 and NASCAR are now, because of the rule restrictions, a glorified bloodsport akin to pro wrestling. They are events...not races. Like the America's Cup, they have become a circus, a show for the masses, not having any real bearing on the advancement or development of the art. If you want to see an open field competition that combines unlimited speed controled only by the skill of the driver, I suggest you take up watching luge or skeleton.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 02-09-2008 at 12:03 PM. Reason: typo |
#27
| F1 Quote:
#28
Tub concept, monocoquce structure, materials, ground effects, computer controls, etc. all the stuff of a modern F1 car came from other applications. And in reality that is forced now beacuse of the spending limits rules. Gone are the days of unlimited R&D money. The only group now that has generally unlimited money for R&D is the tire supplier, and thats because everyone has to use the same tires.
#29
| ****** Quote:
#30
| Jet, Jet Pump, Waterjet, Jet Drive vs Prop | brian eiland | Jet Drives | 45 | 08-27-2010 09:04 PM |
| jet drive? or stern drive? | Toby100000 | Jet Drives | 2 | 08-04-2007 04:32 AM |
| jet drive and engine for tender | ars-technica | Jet Drives | 7 | 04-20-2007 10:32 AM |
| Fonda Jet Drive Engine Linkage | ijw1234 | Jet Drives | 4 | 02-20-2007 08:45 PM |
| Surface drive propeller calculator | Janamon | Propulsion | 0 | 05-28-2006 04:02 AM |
