Old 06-03-2009, 02:08 AM
dladave dladave is offline
Rep: 10 Posts: 3
? about wood deck put on seats of aluminum semi-v
I have an older Alumacraft 16 ft. semi-v that I (wife) would like me to put a deck for her to lay out on when I am fishing. I was wondering if I could put plywood from the bow seat running back to the to the third bench seat simply laying it on the factory bench seats. Would it be too high and tippy? If I am able to do this what thickness of sheet would I need. I am possibly a lttle undepowered with my 9.9 tiller so weight is a factor. Any help greatly appreciated . Nice site here...thanks It's probably obvious I am pretty green so I hope I can understand the terminology....but I sure want to learn...Take care...
Old 06-03-2009, 07:37 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,692
dladave
Wood, when wet and laid on bare ally you will a sticky white hydroxide called poultice corrosion. So you need to protect the surface of the ally, such as painting or a silicone based sealant.
Old 06-03-2009, 11:31 AM
mudman mudman is offline
Rep: 72 Posts: 88
Yes, you can do so. But as mentioned, wood will corrode your aluminum, especially if you use treated ply. I did this on a small flat that I had years ago. You may need a brace, like a piece of angle down the center. Just be sure to keep the wood from contacting the aluminum.
Old 06-03-2009, 12:28 PM
Rep: 1397 Posts: 7,216
Is it going to be a fixed deck? If so, 1/4" will do if you put a three or four of 1X2" stiffeners. Make them run parallel to the centerline of the boat (fore and aft).
Old 06-03-2009, 06:04 PM
Rep: 10 Posts: 3
thanks for replys
Do I need marine plywood? I was just going to put the deck in as needed...so maybe just paint and go?
Old 06-03-2009, 06:26 PM
rasorinc rasorinc is offline
Rep: 682 Posts: 1,130
No, you do not need marine ply but you do want waterproof glue used when they make the plywood. This is shown as an X on the plywood at the end of the grade listing. Example CCX means each side face is a C grade and X = exterior grade. They have ABX, BCX, ACX with A grade on one side meaning no flaws on the face. You can use a layer of waterproof Vinyl as a washer between metal and wood put down with waterproof adhesive. Then prime the wood and use a good enamal on the top surface. ( exterior )
Old 06-03-2009, 07:36 PM
Rep: 10 Posts: 3
Awesome!!! Thanks a million
Old 06-03-2009, 09:59 PM
jnwaco jnwaco is offline
Rep: 10 Posts: 23
The above is absolutely true. I just finished removing a nicely built but rotting plywood floor and decking from my aluminum boat and every single place that the wood touched the aluminum, it corroded. The wood will move and it will wear away the paint eventually, resulting in contact. Not sure what people recommend to insulate the aluminum from the wood, as I'm putting aluminum flooring in my boat.
Old 06-03-2009, 10:09 PM
Naval Architect
If you really want to you can use wood, BUT, you need to protect the wood from becoming wet. Once it is wet and in contact with the ally, that's when the trouble starts.
Having said that any 'wick-like' material that absorbs water and is on contact with ally, you'll get poultice corrosion.
Old 06-03-2009, 11:16 PM
alan white's Avatar
Rep: 1168 Posts: 3,270
Filling in between the seats would be better than paqssing over them. Lighter and a little lower. Also, no contact with the aluminum.
You would have to drill some holes. The holes would be on the edges of the seats, not the tops. Each end of the platform set between the seats would have pins to fit into the holes. One end would have spring-loaded pins. Nothing more than loose aluminum rods a couple of inches long inside of a hole drilled in wood (oak pieces that also are screwed to the perimeter of the plywood (1/4") pieces. Put a spring behind them and a cross-drilled hole/cotter pin to prevent them falling out. Reach under and pull pins to release.
Heavy Lift Deck Barge - Semi-Submersible hassan_esmaeili Boat Design 3 06-13-2009 11:31 AM
Kennedy Kraft 14ft - bench seats to pedestal seats is it worth it??? ChicagoPete Boat Design 4 03-22-2009 01:53 PM
Replacing wooden seats in an aluminum fishing boat mosk22rte Boatbuilding 5 02-10-2009 07:37 AM
make wood deck on aluminum boat?? olboatbob Metal Boat Building 13 08-03-2008 03:08 AM
Removing Seats from Aluminum Jon - Strength Issues LarryJ Metal Boat Building 2 08-11-2005 03:33 PM
