Old 09-15-2011, 01:03 AM
karayelhb karayelhb is offline
About landing crafts
Hi everybody!
I am doing some research about landing crafts especially in their hull forms. But I couldn't find any good resource to describe the philosophy of these boats. Could you please help me if you know any book, webpage, etc.
Baris
Old 09-15-2011, 02:44 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Originally Posted by karayelhb View Post
Hi everybody!
Baris
You meaning landing craft as used by the armed services during the wars or coastal and lake landing craft use today ?? principle will be the same just differant cargo , Google landing craft !! Wow theres a ton of stuff came up !!
Making beautiful boats is a passion never a chore !
Old 09-15-2011, 03:55 AM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 710
The 'philosophy' is they have to be able to drop their loading/unloading ramp near enough to the water's edge so stuff can get on/off without too many dramas.
Old 09-15-2011, 07:34 AM
Village_Idiot Village_Idiot is offline
Rep: 75 Posts: 238
IIRC, the original landing craft were Higgins boats and used at Normandy. The boat was designed/built by Higgins who grew up on the shallow Platte River near Columbus, NE. The boats were big and heavy and relativly shallow for surf work (they still drafted 4 feet at the stern).
Modern landing craft can draft 2 feet at the stern, depending on where their use is intended. Ocean/surf craft still need some depth for better ocean-going performance (see bill munson's boats), whereas inland lakes/river craft can get away with shallower design and operation.
Attached is a pic of a modern aluminum landing craft designed for inland waters. It is 26'x12', diesel w/ Hamilton jet, loaded with 5.5 tons cargo it drafts 9 inches at the front and 22 inches at the rear.
Old 09-15-2011, 01:03 PM
messabout messabout is online now
Rep: 749 Posts: 1,314
If you are researching landing craft and such, you might also be interested in the "Alligator" built during WW2 by FMC corporation. They were butt ugly amphibious boxes with track propulsion. Sometimes used as smaller armed landing craft.
Old 09-15-2011, 08:48 PM
BATAAN's Avatar
BATAAN BATAAN is offline
Rep: 1090 Posts: 1,502
I've had quite a bit of practice with the Higgins LCVP (Landing Craft for Vehicles and Personnel) and this is one tough boat that could operate in 18" of water.
http://www.higginsmemorial.com/design.asp
Old 09-15-2011, 08:49 PM
BATAAN's Avatar
Draft 3' aft but could get off a beach if it had 18" at stern.
Old 09-15-2011, 08:52 PM
BATAAN's Avatar
http://www.freewebs.com/militarymate...igginsboat.htm
Old 09-15-2011, 09:02 PM
BATAAN's Avatar
http://www.aluminumlandingcraft.com/products.html
http://www.billmunsonboats.com/packman.html
http://www.responsemarine.com/LC.htm
etc.
Old 09-15-2011, 09:06 PM
BATAAN's Avatar
Basic idea is very shallow draft to get on/off a beach with little gradient, tunnel stern, strong enough build to take violent battering, enough Vee to give some speed without pounding, a bow ramp to allow roll on/off use and enough power to stay out of trouble. What else is there? For philosophy of landing craft, read about Mr Higgins.
Old 09-15-2011, 10:49 PM
FMS FMS is offline
Rep: 125 Posts: 233
A different landing craft: L-CAT landing catamaran
http://www.naval-technology.com/cont...s/patrol/cnim/
The L-CAT consists of a full length mobile platform operated by hydraulic jacks, which is suspended between the two hulls. During landing operations the platform lowers into the sea thereby lifting the vessel out of the water reducing its draft to approximately 0.8m allowing the vessel to navigate in shallow water and come to shore and beach. During high-speed navigation the platform is lifted in its highest position, improving the vessels sea-going capacities and allowing it to be deployed up to 200 miles from shore.
The French Ministry of Defence acquired four vessels and the first of series is scheduled to be delivered in 2011.
Old 09-16-2011, 12:48 AM
cor cor is offline
Rep: 85 Posts: 94
Here is a landing craft on the small end of the spectrum. 21' long, built from plywood, 90 hp outboard. Sized to haul two ATVs or about 2000 pounds of cargo.
C.O.
Old 09-16-2011, 10:12 AM
BMcF BMcF is offline
Rep: 191 Posts: 459
Something newer in the design of landing craft...
http://www.militaryphotos.net/forums...rine-Commandos
Old 09-18-2011, 07:00 AM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
C.O.
That looks like a good starting point. What about having a couple cat hulls on each side and a small cabin at the rear for access to the cat hulls and the helm? The flat bottom LC would need a stronger bottom since it would be off the water I would think.
Old 09-19-2011, 04:38 AM
ACuttle's Avatar
ACuttle ACuttle is offline
Marine Design Engineer
Rep: 40 Posts: 85
Cat hulls make pretty poor small (<8m) landing craft. Though they've got the deck area, the height needed to clear the wetdeck means your load-deck is pretty high and the ramp needs to be so much longer to give a sensible angle.
If the wetdeck doesn't clear the water there is the same strength problem. In either case bottom strength isn't too much of an issue typically, as stiffening up flat pannels isn't too hard and shell thickness is pretty high up forward for when you ground out - especially as many landing craft aren't that speedy.
-Drew
propulsion power estimating for crafts not longer than 2 m tomazz Boat Design 3 04-29-2011 03:40 PM
Taking off and landing Marvout Multihulls 5 10-12-2010 05:21 AM
Users manual for Lloyd's Special services crafts helena Class Societies 14 04-30-2009 12:47 AM
Power And Prop Selection For Hard-chine High Speed Planing Crafts yades Boat Design 9 02-13-2008 04:00 PM
Pictures of steel and aluminium small crafts? Cigra Metal Boat Building 7 03-09-2005 08:33 AM
