| Boston, I agree 100% with your comments, but I already did that !! The first guy looked like his name was Chester, I thought he was looking at my A$$, so I moved on ! Quote:
| Good eye guys !! Paperwork states 95 Tons and it does need work but I can do most of it myself. |
| Honestly, i didnt expect anything. But you guys were dead on, the work to be done is not excessive. However the construction is another thing. |
| my ex on this site is that these guys know there biz better than most hang out and learn before you build its what Im up to best B |
| Before you design anything or choose materials you need some more information. Presumably there is some stability info with those papers, cross curves maybe a stability book ? I would also try and find the designer who will have much more detailed information. You list 51 tons ballast is this when she is in ballast i.e. ballast tanks full? Between permanent ballasting and adding upper-works you can juggle stability within the requirements for the chosen area of operation and whatever restrictions your authorities will impose. If there are any plans extant then considering that it's a chined vessel it is easy to take the lines off the plans for importing into CAD and intact static stability calcs. If there is enough info in the stability book to carry heavy deck cargo then you are already there. Look long and hard at the machinery too. Cheers
| Origami steel yacht construction | origamiboats | Metal Boat Building | 1051 | 09-17-2010 03:23 AM |
| Steel yacht construction | SeaSpark | Boat Design | 41 | 02-12-2008 03:12 PM |
| What could be an alternative construction of this yacht? | MONJI | Boatbuilding | 5 | 07-03-2006 12:16 AM |
| Looking for books about yacht design and construction | flipper | Education | 17 | 12-28-2005 10:20 AM |
| MEGA YACHT DESIGN & CONSTRUCTION | Daniel Fenton | Services & Employment | 0 | 03-21-2005 10:20 PM |
