| 8ft boat: aluminium or steel? I am wondering what the costs of material would be to build a small 8ft boat if I were to use steel or aluminium, and which would be the best material for a boat this size. |
| Aluminium definitely. Advantages of AL .. Weight, Corrosion resistance, maintenance Did I say weight, on a small boat that requires a small motor, weight is almost the most important thing. |
| 8ft boat - why does it have to be metal? What kind of boat? |
| Fibreglass ![]() If you really want metal, go with aluminum. Forget that, go with steel, it will teach you to never build a small boat from steel again. |
| Frankly, don't build a boat unless you really want to. It is far cheaper to buy a used boat, then spend a little money making it better. And I have build a few... |
| Stainless Steel versus Aluminium | Pompey | Boat Design | 11 | 10-14-2008 07:00 PM |
| Aluminium vs Steel | Wynand N | Boat Design | 78 | 09-20-2007 07:34 AM |
| Protecting Aluminium from S/Steel fittings | MMNet SEA | Materials | 6 | 07-11-2007 06:22 AM |
| Aluminium Boat With Steel Piping | 1995 crew | Boat Design | 5 | 01-30-2006 06:03 PM |
| Aluminium or Steel | Willallison | Materials | 2 | 07-27-2005 05:08 AM |
