Old 11-21-2003, 11:56 AM
vander vander is offline
Rep: 10 Posts: 8
7,45 powercat design
Hi,
I am novice in this forum, so I would be very pleased if I can learn some from you and you from me
I am starting a design of a 7,45 m powercat for sportfishing and I would like some comments from you about the design of the hull.
The data of the boat will be:
Hull lenght:7,5 m
Max beam: 3,75 m
Hull beam: 1,50 m
Displacement: 3600 Kg at 0.4 m draft
The hull would be something like attached.
It will be stepped for gaining displacement for ahead and transverse seas approaching.
Would be a good idea to make an assymetric hull with less angle inside for gaing efficiency (the beam would be increased to maintain displacement)
I don't really know very much the difference between symmetryc VS assymetry hull in powercats.
Best regards
José Luis
Old 11-21-2003, 04:54 PM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
I would make the lower chine much wider. The way it looks there I imagne it to be a wet boat. Hard to tell with only a single view.
Brett
Old 11-23-2003, 03:08 PM
badges65 badges65 is offline
Registered
Rep: 10 Posts: 62
Hi,you might want to look at an IVB hull before you decide,
it will out perform a cat only requires one motor and would be cheaper and easier to build.
you will end up with approx the same dimensions a cat and even more stability!!!
don
http://invertedvboats.741.com/
http://ivb-boats.netfirms.com/
Old 11-24-2003, 06:35 AM
Rep: 10 Posts: 8
Hello,
I´ll com back with more views.
Regards
College for Naval Architecture Archive Education 15 04-07-2008 12:42 PM
Master in yacht design ambas Education 26 05-11-2006 01:47 AM
Looking for the right path to design and build ben_morel Education 44 11-24-2005 03:51 PM
Westlawn Shool of Yacht Design michal Education 9 03-07-2004 08:11 PM
