Old 04-16-2007, 09:07 PM
Previous Member
Rep: 0 Posts: 0
6.5kts With 150 watts
I tested my latest boat today. It ended up heavier than design so a tad more power required than design. The WL beam is more like 480mm than the design 440mm with the extra weight.
Basically it verifies Michlet again. (Many thanks Leo) I am able to do 6.5kts with 150 watts. I had an issue with the capstan drive unit that prevented full power test but hope to sort it out and see what full power can get in a couple of weeks.
The KM as-built is 340mm and my KG is about 280mm so it is quite stable once I am seated. It leans into turns and feels like I could roll it if I steered hard at any speed over 5kts.
Rick
6.5kts With 150 watts-v12_side_view.jpg  6.5kts With 150 watts-capstan_drive.jpg
Old 04-17-2007, 12:44 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
Rick, you have peaked my interest. I would like to know more about your capstan drive set up and the boat. I visited your site and found some great pictures but nothing on this boat.
Gary
"The hand feeds the mind."
Weston Farmer
Old 04-17-2007, 05:33 PM
Previous Member
Rep: 0 Posts: 0
Gary
The capstan drive was developed by a fellow HPB enthusiast. Each of the two tiny capstans are fitted with a roller clutch. The wire that wraps on the capstans is connented to foot pedals that swing from a pivot at the front of the cockpit like pendulums. When one wire is pulling the other is retracting. A bungee cord at the front of the pedals ensures slack side tension on the rewinding capstan. It is a simple system that does not require precision engineering.
Most of my previous boats have used cycle cranks with right angle drive. I have also used oscillating foils for propulsion. The idea with the pendulum arms was to keep my legs low to reduce the KG. This way I could build a reasonably efficient hull that does not require outriggers for stability.
Rick
glastron gt-150 amorris Powerboats 14 02-24-2009 08:09 PM
drop leaf tables $150 each 7393452 Marketplace 0 12-20-2006 02:47 PM
1988 Mariner 150 - help requested ksimpson Open Discussion: All Things Boats & Boating 1 08-14-2006 06:36 AM
lorcha 150 feet fred_heyer Boat Design 0 12-12-2004 05:37 PM
Trevira Core 150 guest12020101217 Materials 2 09-10-2004 08:58 AM
