__________________ Best, Charlie |
| What is your e-mail? |
| Well, Iīll do some more research around marinas, and forums... + Iīll attach in the next days some drawings and dimensions of what I figured out, so you guys can give me your opinion. Best regards, Antonio Casas |
| sketch chine&strakes Well here is what I figured out regarding chines and strakes size. Dimensions are in mm. The chines will run from stern to bow. The strakes closer to the chines will run from bow to begining of 2nd step, and the strakes closer to the keel, will run from bow to the begining of 1st step. Does anyone have another idea? Should this work nicely? Thank´s, Antonio Casas |
| Hi Toplana, since you are the only one answering me here, why don´t you joint into this other forum: 57 knots? 9 tonnes 2x820hp Seatek, chines&strakes dimension? which is the same but with diferent title for "marketing" purposes. I did attach a sketch of what I figured out regarding chines and strakes. give me some coments if you have, please Thank´s A C |
| I really have to insist that if anyone says "that is perfect" they don't know what they are talking about. I am sure there are some "rule of thumb" or some research on this that I have not seen yet but I still think that for such a big and probably expensive boat you should test it. There is no institution in the world that can predict or design a boat better than someone who is willing to do systematic testing. Your drawing looks fine and I think you have a good point from where to continue with testing. BR / N Ps. you dimensions are weight looks very similar to the D Gerr designed HM Pope III. |
| ThanksīNojjan |
| 57 knots? 9 tonnes 2x820hp Seatek, chines&strakes dimension? | AntonioCasas | Powerboats | 14 | 03-21-2008 05:45 AM |
| sprays & chines design | koanda | Boat Design | 1 | 11-29-2007 03:42 AM |
| Reverse strakes, planing chines | skypoke | Boat Design | 13 | 05-05-2007 02:17 PM |
| Letting Stringers & Chines "Stand Proud" from Transverse Frames | timgoz | Metal Boat Building | 16 | 10-29-2006 09:05 AM |
| Hard or soft chines & their effects on rolling | Parke Brinkley | Boat Design | 3 | 07-22-2004 04:05 PM |
