Old 08-04-2007, 10:26 AM
jelfiser's Avatar
jelfiser jelfiser is offline
Rep: 37 Posts: 98
a 5.5 m design for a friend ( and for anyone wants it ) :-)
just playn around a concept for a small boat 5.5 for a friend .
here hull and hydro.
The hull is from 8 mm plywood/epoxy , bulkheads 1cm plywood
the structure will be completed laminating some diagonal in fiberglass over urethane tube
may be someone can give his impression ?
a 5.5 m design for a friend ( and for anyone wants it ) :-)-.jpg
Old 08-04-2007, 12:08 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
Nice practical build. The hull in 10mm would make a good simple alternative for the novice, with a small weight penalty but more durable, suitable for stitch and glue.
Alan
Old 08-04-2007, 02:17 PM
Rep: 593 Posts: 2,054
I opened the Rhino file and looked at the hull, surface analyzed the boat and projected the panels to 2D.
Couple of things.
First, I think you can make this boat in 6mm if the glass schedule is correct. I would rather see it lighter than heavier, considering the type of boat that it is.
Secondly, that second hull panel moving out from the centerline is potentially going to be more than a little problematic in an 8-10mm build. A lot will depend on the size of the rig you are specifying for the boat, what sort of load and what type of keel will be fitted.
Very nice shapes and it could be a fairly simple project to construct in new-builder friendly stitch and glue methods.
Chris
Old 08-05-2007, 05:11 PM
Vega's Avatar
Vega Vega is offline
Rep: 127 Posts: 1,606
Nice hull. Show us the rig , keel and rudders please . What’s the boat's program?
Old 08-05-2007, 05:26 PM
It's Rhino, Vega.
Old 08-05-2007, 05:46 PM
Vega's Avatar
Originally Posted by Chris Ostlind View Post
It's Rhino, Vega.
Not what I mean. Probably the confusion cames from "my" English
By boat program I mean what is its intendeed use (racing, daysailing, coastal cruising and so on)
Old 03-13-2008, 12:57 PM
jelfiser's Avatar
Rep: 37 Posts: 98
slowly but arrived version 2.0
Excuse me for so long time i spent before writing
so here it is, i wanted some more power and stability ... still working on it
the boat will be a trailerable daysailer.
more details have to come
a 5.5 m design for a friend ( and for anyone wants it ) :-)-wiew.jpg
Be a friend to Alan White Appeal Bergalia Open Discussion: All Things Boats & Boating 91 07-22-2007 05:14 PM
