Old 08-26-2008, 05:53 AM
ASM ASM is offline
Rep: 56 Posts: 131
~3m Power trimaran design, 8 Hp
Hello all guys,
As some of you have seen before, I like the trimaran designs (which are almost non existing in The Netherlands) and have started some threads regarding those type of vessels. The faux trimaran (displacement 9 m) with a lot of help from Rick and the question of suspended outriggers on a trimaran. The displacement one is in a model building phase, cutting by CNC.
But, as my garage is not big enough and my building skills close to zero, I would like to start off with a small trailable power trimaran, ~20+ knots with minimal amount of outboard power. The design goal/base would be:
http://www.amorousmarine.com/portfolio.php?boatId=15
Which proves that it is possible, and the looks of:
http://www.amorousmarine.com/portfolio.php?boatId=16
Furthermore, it needs to cary 1 person and occasionally a passenger, easy to build in plywood (later on maybe foam cored), so outriggers similar and symmetrical (?, or one completely vertical flat surface on the outside face), and clean flat sides/lines like the Wally power style....
Would this be possible ? would there be big no-no's in this dream ?
Old 09-01-2008, 04:21 AM
Rep: 572 Posts: 646
Hi, I do love also power trimarans, but do you think it's worth all the work for a 3 meters 8 HP boat? A small doris would be lighter, simpler, cheaper and probably as fast for a 3 meters boat.
Old 09-01-2008, 04:56 AM
ASM ASM is offline
Rep: 56 Posts: 131
I do agree with you but as for so many techincal stuff in life, new things and good looking things are attractive. PLus I feel stability is better in a trimaran compared to a dorry and the 8 Hp was a goal back then, basically I would like to end up with electric version. Kinda like he next step from waterscooters to elec. trimaran as a watertoy.
Old 09-01-2008, 05:34 AM
Rep: 572 Posts: 646
No it's not feasible and has no meaning.
Old 09-01-2008, 06:56 AM
ASM ASM is offline
Rep: 56 Posts: 131
Ilan
not feasible and no meaning... for some of us that is the trigger to proove it does work..... what are your statements for this conclusion ? Battery power/weight ?
Small power trimaran with suspension ASM Boat Design 15 08-20-2008 07:16 AM
Trimaran Design rapscallion Multihulls 27 02-25-2007 07:57 PM
Design Formulas and Trimaran Help photojoe Boat Design 2 11-03-2005 04:49 AM
Power Trimaran BayouDude Boat Design 19 05-14-2005 05:32 AM
Trimaran Design BluWtrSail Boat Design 13 04-22-2005 08:46 AM
