  #166
Old 07-10-2007, 05:01 AM
archnav.de's Avatar
archnav.de archnav.de is offline
Rep: 60 Posts: 208
bnautika,
Normally we try to work always via step AP214, when we dealing with CAD-files and try to make them such as robust that there are no difficulties to work with in different CAD-Systems. Beside the Step file we produce an ACIS 4.0 file for AutoCAD and other ACIS based software. The second large geometric kernel is Parasolid (UG, SolidWorks, Microstation, SolidEdge). So that is why we involve in .zip files these three files and other documents.
In respect with PDF for us the marketing aspect is not so important, but the distribution of documents, drawings and 3D-Models via a certificated und secured file.
The basefor the new 3D-PDF file is the PRC-Format.
For the long run the PRC-file, a kind of compressed STEP AP214 file, could play an important rule in the distribution of CAD-Models. We will wait and see.
Cheers
Bernd
  #167
Old 07-10-2007, 07:16 PM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
Bernd I tried opening the step file using rhino and solid works. Solid works wouldn’t open it , RhinoV2 did . If you don’t mind me asking what size was the models file in its native file format.
  #168
Old 07-11-2007, 03:20 AM
archnav.de's Avatar
Rep: 60 Posts: 208
bnautika,
Please tell me the name of the file you tried to open, so that we have the same example.
Cheers
Bernd
  #169
Old 07-11-2007, 03:54 AM
Rep: 499 Posts: 489
Bernd the file was PCM-H-457_rev1_.stp
  #170
Old 07-11-2007, 05:39 AM
archnav.de's Avatar
Rep: 60 Posts: 208
The file name could be:
PCM-5015-H-457_rev1_.stp
PCM-5016-H-457_rev1_.stp
or
PCM-5017-H-457_rev1_.stp
  #171
Old 07-11-2007, 07:25 PM
Rep: 499 Posts: 489
Sorry bernd PCM-5015-H –457_rev1_.stp
PCM-5016-H –457_rev1_.stp
Both would not open in solidworks but did in rhinoV2
  #172
Old 07-11-2007, 08:45 PM
SamS SamS is offline
Rep: 10 Posts: 3
Anybody try eDrawings?
Have you guys tried the free eDrawings 3D viewer from SolidWorks? You can find more information and download here http://www.solidwork.com/pages/produ...eDrawings.html
The eDrawings publisher can be used to create a few different file types, an edrw file which requires the end user to have already installed the eDrawing viewer software or you can create a self executing edrawing file so that the user does not need to download and install anything. If you require the eDrawings professional version allows the ability to enable or disable the users ability to the measure and can also password enable to viewer file to protect your designs. There is also the ability to create an html file so that you can add to your web site and of course plenty of tools to markup and red line the edrawing file so that two users can collaborate on a design. Can also of course do all the "normal" pan, zoom, rotate, hide exterior components so as to see interior, set individual components to transparent so user can see through them but still see the transparent components shape. Can also create dynamic section views by dragging a plan through the design and the plan will section as the user drags.
I think the one benefit of the Adobe 3D program is the ability to format as a brochure and easily add text, this might be accomplished with edrawings as well by embedding into a word doc but I have never tried.
Maybe give it a try, just be sure to download the correct software per your CAD program. Oh yeah, it can also view native dxf and dwg files as well.
Sam
  #173
Old 07-12-2007, 05:00 AM
archnav.de's Avatar
Rep: 60 Posts: 208
I have no problems with SolidWorks 2005, but some with Rhino 4.0. (Wrong solids in 5015)
The problems with Rhino are quite normal; because Rhino is more surfaces based and in this sense extremely good, but have some problems with solids. So Rhino is great for surfaces and iges-files.
For equipment exchange, we are looking more forward for solids, assembly structure and other information. There is STEP AP214 the best.
Cheers
Bernd
  #174
Old 07-12-2007, 05:35 AM
archnav.de's Avatar
Rep: 60 Posts: 208
Sam
Our strategy is quite clear, for documents incl. their certification PDF is the international standard and available on all computers. For 3D-Models STEP-AP214, Acis or Parasolid are the best for the exchange between CAD-Systems.
So the first step was, that we decided to involve in PDF-documents via a link and a .zip-file 3D-models in the above mentioned formats.
Since Acrobat 8.1 there is involved a very good 3-D viewer and the new possibility of the PRC format.
Now everyone has enough instruments to explore documents und 3D-models via PDF-files. There is no need for other possibilities, because to work with the models you need always in the end our own CAD-system.
Cheers
Bernd
  #175
Old 07-12-2007, 10:35 PM
Rep: 499 Posts: 489
Bernd I finally got your file into solidworks by filtering it through RhinoV2, exporting it as a IGES file for SW surfaces. There seems be two types of uses that we are talking about, the high end, needing as much information as possible for construction and manufacture or the other end that just want simple models to show layouts and for rendering. Also the difference between the need for solids over surfaces.
  #176
Old 07-12-2007, 10:40 PM
Rep: 499 Posts: 489
SamS Yes have used edrawings 3d fantastic on something’s not so good on others, trimmed nurbs don’t always make it.
  #177
Old 07-13-2007, 03:58 AM
archnav.de's Avatar
Rep: 60 Posts: 208
At the end there should be one model for the different uses. From my point of view is that a STEP AP214 file, involving surfaces, solids, assembly structure and so on.
In my case I have produced the .stp file with SolidWorks 2005 so I'm completly astonished, that you can't open it. This was never reported up to now. But never the less, in the case of SolidWorks you can try the .x_t file, because Parasolid is the Kernel of that CAD-system.
  #178
Old 05-21-2008, 04:28 AM
archnav.de's Avatar
Rep: 60 Posts: 208
3D-PDF with .stp annex
Here is an other 3D-Equipment catalogue for steering gears
http://www.archnav.de/HATLAPA_steeri...ram_rev3__.pdf
Cheers
Bernd
  #179
Old 04-28-2009, 06:50 AM
imrankhaled imrankhaled is offline
Rep: 10 Posts: 20
does any one has a 3d model of 750 bhp marine engine please mail me at imrankhaled@yahoo.com
Original Equipment Hull Decals bayhawk Marketplace 1 08-02-2004 01:05 AM
