Old 09-09-2009, 03:36 AM
dobsong dobsong is offline
Rep: 63 Posts: 57
A 39' "downeast" influenced design - Feedback Request
I'm part the way through getting a boat designed and was thinking I sould get some feedback from others before we finalise the design and begin construction (this is scheduled to begin early next year).... So here goes! Any comments, criticisms or suggestions for improvement welcomed.
She is for open water coastal cruising in Bass Strait, around Tasmania and up the eastern coastof Australia. Most of the time I will use her single handed or with a friend (or maybe two), maybe once every month or two there will be 6-8 guests on board for day cruising.
Dimensions are 11.9 metres LOA, 11.7 metres DWL, Beam is 3.3 metres and draft is 1.1 metres. Displacement is anticipated to be 6,100Kgs fueled and loaded for cruising. She has a rounded "ducktail" stern
She will be powered by a 315hp Yanmar and will carry 700 litres of fuel. We are expecting a cruise of 14-15 knots and a top of 19-20 knots. She is to be built using Celery Top Pine (a wonderfully tough timber from Tasmania) in an expoxy composite.
These are the profile and layout drawings.
A 39' "downeast" influenced design - Feedback Request-revised-profile-18-august.jpg  A 39' "downeast" influenced design - Feedback Request-layout-14-july.jpg
Old 09-10-2009, 03:46 PM
Rep: 696 Posts: 1,232
The profile view shows a very handsome boat. That view also suggests that it will operate in mainly displacement mode which further suggests that the quoted speeds are vastly overstated. Surely you will not need all that power if it is, in fact, a displacement boat.
Old 09-10-2009, 05:44 PM
apex1
Uhhh?
http://www.balta.fr/lovstar.html
the most beautiful of her kind as far as I know.
but what do I know............................................
Regards
Richard
Old 09-10-2009, 07:31 PM
Rep: 63 Posts: 57
Displacement? No a semi-displacement
Boats of a similar size and hull shape easily do the speed I have been advised. e.g. http://www.pbmy.com.au/range38_intro.html
So I am surprised at your comment. What do you base this on?
Old 09-10-2009, 07:36 PM
Rep: 63 Posts: 57
Originally Posted by apex1 View Post
Uhhh?
Regards
Richard
Yes a lovely looking boat..........
Old 09-10-2009, 07:41 PM
Rep: 63 Posts: 57
Displacement?? (2)
She has a very fine entry and then flattens out considerably as you go aft - you could call her a semi-planning design.
Old 09-11-2009, 03:24 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 513 Posts: 940
Dobsong, the profile looks nice, I would have assumed the same as Messabout when you track the rabbet line & imagine the buttock lines rising similar, the example Apex has linked is sweet & I admire his taste in that with much more cockpit space with the conventional transom. Are the speed figures as calculated by David? "cos he's known as a pretty cluey guy. All the best with it from Jeff.
Old 09-11-2009, 03:39 AM
apex1
Well as her sister of Patric Balta but tha latter with less than half of the power to the same performance!
I could do such a boat btw. at about 300.000$ in wood Epoxy
Finest wood, and prime equipment, and (using now 800 tonnes of Ep resin a year) not the least quality in every aspect.
This was not a business offer, or a advertisement, just to talk about........
Old 09-11-2009, 07:32 AM
Rep: 63 Posts: 57
Quote
Is that 300,000 US or Aus - has to be delivered to Melbourne, Australia
Old 09-11-2009, 07:34 AM
Rep: 63 Posts: 57
Speed Estimates
Yes calculated by David
Old 09-11-2009, 09:19 AM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
Well yes, if you apply Crouch's speed formula to the given specs, the top speed comes to a bit over 18 knots. Crouch's is pretty good for a full planing hull, which this is not. The aft hull shows the typical highly warped form of Maine lobsterboats with a fairly flat, if highly twisted, aft run. I am also doubtful of the speed prediction. One caution of the speed prediction is the very steep keel rise aft. If it did get to the predicted speed, I would expect the bow to be way high by over 10 degrees and forward view to be almost non existent. The power to make this speed is another issue.
Skeptical arguments here are based on scant information and should not be taken as gospel but should cause a deeper study of this boat's potential.
Beautiful boat, by the way.
Tom Lathrop
Old 09-11-2009, 03:05 PM
apex1
US ex works Turkey.
Richard
Old 09-11-2009, 05:10 PM
Rep: 63 Posts: 57
Speed and bow rise
Thanks for your comments Tom - the potential for excessive "squatting" is a concern that we will have to work through
Old 09-11-2009, 05:49 PM
My remarks about speed and power were predicated on the appearance of the afterplane of the boat. To plane or not to plane is closely dependant on the angle of the quarter beam buttock in the run. An angle of four degrees is just about all the rise that might allow planeing performance. The normal planeing hull will have zero degrees of rise and some even have negative rise which coaxes the boat to run on an even keel. The choice of negative angle, or not, is somewhat dependent on weight distribution and sometimes decided on the basis of expected sea conditions ang entry shape. Your drawing shows a rise of considerably more than the optimum. In displacement mode you might expect something on the order of 8 or 9 knots. Probably less except when you are content to pull half the ocean behind you. Be that as it may, it is still mighty handsome.
Old 09-11-2009, 06:04 PM
Rep: 63 Posts: 57
Lines
My brief to the designer is to optimise for 14 knots - attached is a scanned document of the lines does this make things clearer?
bridge design - feedback request expedition OnBoard Electronics & Controls 65 09-16-2010 08:11 PM
16-18' "Sit-in" Planing Monohull ("Trapwing") Doug Lord Sailboats 124 04-23-2009 06:14 PM
Boat "workshop" including a "testing tank" zmfmd Open Discussion: All Things Boats & Boating 0 08-08-2007 05:43 AM
colvin design "althea" looking for feedback islander ken Open Discussion: All Things Boats & Boating 2 11-28-2005 01:47 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 03:03 PM
