#31
| Fuel consumption Quote:
Anticipating a little less consumption (say 20-22 lph) wanted 350 nm range as minimum @ 14 knots. Expecting that range will increase very significantly for a slow cruise (say around 8 knots). Trying to get all elements (prop, hull, engine etc) optimised for 14 knots. There are other similar boats that indicate all is achievable. |
#32
| Celery Top Quote:
Celery Top logs available for milling on the west coast. Around $20,000 for the quantity (+15%) I need. Will use celery top for other parts (in addition to the hull) also using marine ply for a few places. Builder, designer and myself all agree we will end up with a very solid hull. Apart from the expense and some problems with oils, my view is Huon is too soft. Also its very hard to get it in suitable lenghts for a 40' boat. |
#33
| Power and Speed Quote:
For the 315 hp max output using 85% (again a very conservative approach) of this figure (268hp) shows that the craft should do 21.7 mph or 18.9 knots. To do 14 knots or 16.1 mph, same coefficent, the actual HP required is 125 hp. |
#34
| So, essentially the same as my quick estimate. The consumption I gave was based on Yanmar's own prop & power curves. If they are correct, I'll be surprised if you can get much better than that - it equates to 2.5 nmpg, which is pretty good going for a semi-displacement boat. Having said that, my own recent experience with a Yanmar 6BY260 showed that (in my instance at least) Yanmar's figures were quite conservative. Just as an aside, I reckon you'll find the engine is happier running at around 2400 rpm - which should give you 100shp and around 12 knots, or thereabouts. You will certainly see a BIG jump in your mileage if you slip back into displacement mode: 8 knots max I'm a bit short on time at the minute, I'll take up the debate with you about tender access at another time... ![]()
#35
| Speed and fuel use at cruise Quote:
It is a bit of a “SWAG” (scientific wild arsed guess) but given we are using less than half the available horse power at 3,000 rpm (or half allowing for losses) I am hopeful 20 litres per hour is achievable. This seems to be supported by outcomes achieved by similar boats. What do you think? Regards, Graeme |
#36
#37
| Propeller curves can only ever be regarded as an estimate IMHO. There is simply too much variation from boat to boat and installation to installation for it to be regarded as anything more than that. The only definitive consumption figures come when the boat hits the drink. They should, however, give a reasonable approximation and anyone with a bit of common sense would make allowances for any variation from theoretical to real life. Your designer has suggested that you'd need 700 L to run 350 nm at 14 knots and my quick estimate would suggest that that's pretty much on the money, allowing a 10% (70L) reserve. That is (as Mas pointed out) assuming calm conditions. My quick look at the 6LP's prop curve earlier (I assume it is the LP that you're planning to use...?) suggests that 27-2800 rpm ought to yield aound 130 hp at the crankshaft. This is under load - that's what the prop curve is intended to estimate. At 2800 rpm the engine will use around 25 lph, according to Yanmar's figures. Based on that, 20 lph may be a bit hopeful... but as I said, my recent experience with the 6BY yielded substantially better fuel consumption than the published Yanmar figures. Personally, I would expect the worst and (hopefully!) be pleasantly surprised when the boat performs better than expected.
#38
| Fuel Consumption Quote:
Also the displacement calcs are "realistic" with full tanks and cruising gear included. The graphs I forgot on my last attached Some information that supports my fuel consumption "guesstimates" - The Rumery 38 with the 315 hp Yanmar is reported in the Wooden Boat article as having a top speed of 32 mph and using 6 gallons (23 litres) per hour at 30 mph. A surprising figure! I’m guessing what was actually meant was that it averaged 6 gallons an hour for 100 hours operation at speeds of up to 30 knots, still OK in my book. - Given the boat being designed for me has more beam, bigger tanks and a bit more in the cabin fit out (an extra 1,100Kg displacement fully loaded above the 5,000Kg reported for the Rumery – was it 5,000??) I’m assuming we will loose around 10 knots top end speed and have some increase the fuel consumption. - The 32’ Cheviot (32’ x 10’ 10” x 3) built by Tim Phillips is shown in her trip across Bass Strait as having a top speed of 24 knots and that with a 300 hp Yanmar at 3,000 rpm she travels at 15 knots using 22 litres of fuel per hour. - The Fairway 36, a semi-displacement hull that displaces 7 tonnes fully loaded, has a top speed of 19 knots when fitted with a single Yanmar 6LP-STP. With this engine at a cruise speed of 15 knots the fuel consumption is reported to be 19 litres per hour. But at the end of the day these are interesting "facts" that I use to give me some comfort (along with calculations from the designer) - the real test will be when she is launched and I do a decent run in her with some accurate measurement of fuel, speed and distance. On thing I am sure of, she will do a whole lot better in "real world" cruising than a lot of production boats - you just have to read some of the reviews where they say 3-5 liters a nautical mile is economical cruising. And I think she will look a whole lot better doing it. Regards, Graeme dobsong@bigpond.com PS email me for more details on the $$ for Celery Top |
#39
you folks pay a fortune for timber down there 1 cubic meter = ~27 cubic feet 1 cubic foot = 12 board feet 12x27=324 board feet $4,000/324=~$12.35 a board foot dam you guys would die if you knew how cheep wood is round here |
#40
The next step down "malaysian red cedar" is about 2/3rd the price, but destroys rain forests and OranguTangs. By the time we ship timber from you to me, take into account the exchange rate, that makes it even dearer. How about a couple of Care packages :-) |
#41
| Timber prices in Australia Yes it hurts when you pay around $Aus100 a metre for 240mm x 42mm dressed hardwood and get told thats a good price! Makes you think about all the really great Australian hardwood that is chipped and sold for a few dollars a tonne.... but thats the "economic rationalist arguement that has enamoured our policy makers here! Let the buggars charge what the market will pay (rather than what it costs.... and because we are a captive audience we pay... and pay... and pay |
#42
#43
| not sure what shipping costs but I could organize a container in about a heartbeat of any north american hardwood you want about the only ones I dont have a handle on are live oak and black Locust everything else this new mill I been going to has got it and dirt cheap most in clear premium is $2 a foot cherry and black walnut is $4 half that for lesser grade lumber white oak is my personal fave which I got for $1.50 a foot just a few months ago they cut heavy at around 5/4 or 9/4 on the white oak they will plane it for you if you want to avoid shipping mill but I prefer to mill my own when Im ready to use it course your paying for that shipping I think planing is C 0.20 a foot the mill is stacked to the gills with lumber at the moment if you guys wanted any large quantity Im sure I could do even better than that give me a species and a quantity and I can get you a quote tomorrow I gotta call em anyway so its no big deal I wonder how much a container can hold |
#44
| Container Load? Quote:
________________________________________ |
#45
When the Plantations get large enough, and the price is driven down, we may be able to start building guilt-free wodden boats again. |
| bridge design - feedback request | expedition | OnBoard Electronics & Controls | 65 | 09-16-2010 08:11 PM |
| 16-18' "Sit-in" Planing Monohull ("Trapwing") | Doug Lord | Sailboats | 124 | 04-23-2009 06:14 PM |
| Boat "workshop" including a "testing tank" | zmfmd | Open Discussion: All Things Boats & Boating | 0 | 08-08-2007 05:43 AM |
| colvin design "althea" looking for feedback | islander ken | Open Discussion: All Things Boats & Boating | 2 | 11-28-2005 01:47 PM |
| Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" | Vibtor | Software | 0 | 10-02-2004 03:03 PM |
