| 38 sailing hull design This is an idea i have been kicking around , it is a radius chine sailing hull about 38' . Please give some advice or critique. |
| It's sooo double ender I don't know which way is the bow How's the hydrostatics? |
Design length : 37.422 Length over all : 37.635 Design beam : 11.000 Beam over all : 11.293 Design draft : 1.750 Midship location : 18.711 Water density : 65.016 Appendage coefficient : 1.0000 Volume properties: Displaced volume : 274.08 Displacement : 7.955 Total length of submerged body : 34.237 Total beam of submerged body : 9.889 Block coefficient : 0.4626 Prismatic coefficient : 0.5343 Vert. prismatic coefficient : 0.7022 Wetted surface area : 262.50 Longitudinal center of buoyancy : 17.817 Longitudinal center of buoyancy : -2.610 % Vertical center of buoyancy : 1.052 Midship properties: Midship section area : 14.983 Midship coefficient : 0.8658 Waterplane properties: Length on waterline : 34.237 Beam on waterline : 9.889 Waterplane area : 223.03 Waterplane coefficient : 0.6587 Waterplane center of floatation : 17.881 Entrance angle : 18.997 Transverse moment of inertia : 1252.7 Longitudinal moment of inertia : 12716 Initial stability: Transverse metacentric height : 5.623 Longitudinal metacentric height : 47.447 Lateral plane: Lateral area : 42.236 Longitudinal center of effort : 18.675 Vertical center of effort : 1.051[ATTACH]38 rd de.txt[/ATTACH] |
| the bow is the front part |
| A bit too boxy sections for my taste and a bit high Cp.. What's the material? Steel/alloy could have some more rocker and dead rise on the bottom so the rounded chine would be easier to do. For other materials bit more roundnes. BR Teddy |
It is an exercise in radius chine and a barge section, the bottom would be dead flat athwart until the start of the radius , much like a junk hull ,with the idea of shallow draft , maybe twin keel arrangement . Frank |
Frank |
| Put a rather large wine glass keel faired in and round out the last 4-5' and it wouldn't be that much different than my Willard 30. Easy Rider |
| BR Teddy, In keeping with the shallow draft , I think that keeping the Cp around .55 , is sort of necessary for the stability. Frank |
But I like the concept . A transom stern would make more sense , but i like the look canoe stern ,when it is right . Frank |
| This is simple boat. Have some of this kind in Sweden. Some are good. |
| Here it is with changes . I left the lines indicating the area of radius chine . I am not sure if it is the right way to approach this or not . new Hydrostatics Design length : 37.422 Length over all : 37.655 Design beam : 11.000 Beam over all : 11.326 Design draft : 1.750 Midship location : 18.711 Water density : 65.016 Appendage coefficient : 1.0000 Volume properties: Displaced volume : 236.22 Displacement : 6.856 Total length of submerged body : 32.169 Total beam of submerged body : 9.531 Block coefficient : 0.4402 Prismatic coefficient : 0.5374 Vert. prismatic coefficient : 0.6627 Wetted surface area : 235.40 Longitudinal center of buoyancy : 17.367 Longitudinal center of buoyancy : -4.177 % Vertical center of buoyancy : 1.071 |
| hull form design of sailing ship | liviper | Sailboats | 9 | 07-21-2009 08:45 PM |
| Sailing hull design | GolfPro | Boat Design | 0 | 08-16-2005 09:02 PM |
| New software: Sailing Hull Design Method | Mario | Software | 19 | 04-26-2004 12:49 AM |
| Sailing Hull Design Method | Mario | Boat Design | 0 | 04-09-2004 05:21 AM |
| Sailing Hull Design Method - FREE | Mario | Software | 1 | 03-29-2004 01:27 PM |
