#106
| Not In Theory Quote:
Incorrect. The cavitation initiator -- a cone or flat plate -- is FORWARD of the bubble. IN THEORY since it is in direct contact with the water a passive sonar could be located inside it. Torpedos have also used magnetic homing. |
#107
| Stonebreaker, you seem to have a very open mind to (and even a philosophy of) human ingenuity and innovation, for the invention of things that people say are impossible. Now this is why I find your position on this subject so suprising. You seem to be primarily thinking about this situation through the defensive position. It seems to me that it is always going to be easier to attack something than to defend it. Defensive technology generally plays catch up with attacking technology. By the time it catches up, there is something new to defend against. I mean what defensive technology has triumphed (and continued to) over an attacking technology? this seems especially true in military examples. A new armour, means a new armour piercing, a new radar, means a new stealth system, etc, etc. Whats that saying, "sometimes the best defence is a good offence?" I think there is something in that for this debate. Sadly, if we humans have proved ourselved good at one thing repeatadely, it is that we are great at inventing ways to kill each other. The ST, while still in pioneering stage, may turn out to be one of these. I think from the evidence presented so far, if it was operational today, then it would be a most formidable weapon, and I doubt very much that the defensive weapons of today could adequately defend a ST attack. Remember, if a ST is destroyed on the way to its target, then the sub does not automatically die, and maybe only one of the ST's it would be launching would need to make it through for the target to die. Once the appropriate ways to defend from it had been developed, then the ST would most probably have developed new ways around these defenses- possibly like the example I gave, or there will just be some other new weapon that will supercede this technology. |
#108
| This little battle is getting tiring, boys. I don't recall F. ever saying that intercepting a torpedo, whether at 30kt or 300kt, is against the laws of physics. Of course it's not. But I also don't recall S. ever proving that the technology to do so is feasible at present. Which it's not. Please, guys, sit back and take a look at the last four pages of this thread. Was anything productive actually said? Do either of you have a clue what the other is actually saying? Technology cannot be created by willpower alone. Even huge amounts of money cannot always create solutions. As recent US missile defence tests have shown, the chances of actually shooting a projectile out of the sky are pretty slim, even when the target has a homing beacon on it and the interceptor has radar, infrared, GPS, and a device to track that homing beacon. Bullets from supersonic weapons simply disintegrate within a few feet of hitting water- it's not at all easy to go fast underwater, let alone hit something moving fast underwater. We may be able to do this in future, but at present it's not something you can use on the open ocean. BTW: Quote:
#109
Your assertion that "a good offense is the best defense" is exactly right. I agree with it 100%. That's why I believe the ST is a bad technology - it has that huge flaw of giving away the sub's position. It's not like a regular torpedo, either - the difference in sound between a regular torpedo and an ST is the difference between a bow and arrow and an AAMRAM. The harpoon missile is a much better solution, IMHO, since it does not necessarily give away the sub's position. I definitely believe in human innovation and invention. That doesn't mean you can't make a wrong choice. A good example of that is in racing, particularly amateur racing. Different guys try different combinations of parts and have varying levels of success. For example, one guy might spend five thousand dollars on parts for his car and gains, say, 1 second in the quarter mile. Another guy might spend eight hundred dollars on an identical car and pick up just as much or even more speed. I've seen it happen many times. It all depends on the technology you choose and the level of skill with which you execute. [edit] A better example that I just thought of is Edison's use of direct current. It worked, but had the huge flaw of not being able to be transmitted more than a mile without a lot of loss. AC current solved this problem because you can use transformers with AC.
__________________ Stonebreaker Ph.D in Redneck Engineering - Piling it higher and Deeper. |
#110
#111
Here's a site with some more details on torpedo active sonar: http://www.naval-technology.com/cont...iles/eurotorp/ You really shouldn't be so quick to dismiss human intellect. You've stuck your foot in your mouth at least three times in this discussion so far.
#112
| If you go after the sub instead of the munition, the sub only gets one shot. http://en.wikipedia.org/wiki/ASROC And, if a supercavitator is fired at a sub, we can respond with an even faster weapon: http://en.wikipedia.org/wiki/SUBROC Ours has two advantages: It's faster, because it flies smart and not hard; and the torpedo it drops in the water is guided. Or, you just use a nuclear depth charge if you just have sort of a general idea where the enemy is.
#113
| interesting.. I was reading Crush Depth by Joe Buff and they mentioned the Shkval torpedo. Quick background, its 2012 and the U.S. is involved with a ww3 type scenario vs. Germany and tactical small yield nuclear weapons are the weapon of choice, but only underwater to "minimize" the effects of the radiation. Totally unrealistic, but a great read. Basically there are two state of the art subs, U.S and German hunting eachother in the Hunt for Red October style except with nuclear weapons. They seemingly routinely fire a nuclear tipped weapon to detonate infront of and therefore prematurely detonating an incoming identical weapon fired from another sub. Obviously fiction, but then again walking on the moon was science fiction until we actually did it (supposedly). But thats another discussion. |
#114
| Incorrect again. Quote:
#115
| Newflash Quote:
#116
| Supercavitating Projectiles Quote:
"As I said earlier, use the first bullets in a rapid fire stream to open a hole to the target. Each bullet goes a few meters farther until the bullet stream intersects the torpedo path." NOT needing to do this is WHY supercavitating bullets and projectiles are being developed. |
#117
| Maroons Quote:
The DUMBEST use of the word "supposedly" EVER. It's not another discussion because there is nothing to discuss. It's on a par with the idiots who try to say an airliner didn't crash into the Pentagon or that ordinary aircraft contrails are "chemtrails." |
#118
| I bet I can beat it though... Supposedly your not arrogant, combative and antagonistic for little to no reason at all. Anyways, I just figure someone like Richard Branson (virgin atlantic) would have "moon base" tours or something by now. But personally I'll take their word for it. |
#119
| Progress Quote:
SpaceShipOne was also the first all composite airplane to go supersonic and the first supersonic airplane developed without government funds as well as being the first all composite spaceplane. The budget being discussed to develop a tourist version of SpaceShipOne is not even the cost of a single new 747. |
#120
| dont worry boys :bubbas navy got something to counter it,,,,,,,longliner |
| torpedo | Shuggy | Propulsion | 12 | 10-20-2005 07:29 PM |
| Want to add a torpedo stern to a 30' cape lsland lobster style boat | rbeck | Boatbuilding | 0 | 09-01-2004 05:07 PM |
