  #121
Old 12-08-2009, 12:11 PM
frank smith frank smith is offline
Rep: 154 Posts: 670
Originally Posted by wardd View Post
reminds me of a bolger AS 29/39
its what ive been studying
I think there a lot of the same ideas that Bolger had.
Fair amount of rocker , little flair , high free board for reserve stability,
and decent ballast . Very cool . It shows that there are many ways to go with the form , but if you change one part , all the others have to be changed also .
  #122
Old 12-08-2009, 06:53 PM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 679
Originally Posted by frank smith View Post
This is one form that the sharpie can take .
http://chrismorejohn.blogspot.com/20...siteagain.html
Fantastic Frank !
I have been looking for info on this ( Hogfish Max. ) boat for a long time.
Thank you.
How big a reproduction are you thinking and do you have crew and money dripping off your butt?( PAR2009)
  #123
Old 12-08-2009, 06:56 PM
wardd wardd is offline
Rep: 443 Posts: 925
i think the important thing about the as 29/39 shape is to keep the sides and keel the same shape and of course weight and balance, but it seems scalable to me
  #124
Old 12-10-2009, 11:01 AM
Rep: 154 Posts: 670
Originally Posted by boat fan View Post
Fantastic Frank !
Thank you.
Good luck on getting much info on the design from Chris Morjohn .
But I think there is enough info out there to get the idea .
  #125
Old 12-10-2009, 11:11 AM
Rep: 154 Posts: 670
I dont know how this worked out for the AS39 , as it is basically the the 29
stretched out . Both having a beam of 7'10" to accommodate plywood construction . The AS39 would make an excellent live a board coastal cruiser .
you could get a large central pilot house out of it and reduce the the freeboard fore and aft . you would lose full standing head room and the aft cabin , but if it were just for me I would not care .
  #126
Old 12-10-2009, 11:19 AM
Rep: 443 Posts: 925
the 39 appears to be a stretched 29 with the same beam
what appeals to me beside the max use of room in the dimensions is that something like that could be legally trailered
  #127
Old 12-11-2009, 12:11 AM
souljour2000's Avatar
souljour2000 souljour2000 is offline
Rep: 146 Posts: 334
I am very interested in how Chris Morejohn did his portholes on "Hogfish maximus". His smaller "hogfish" and he and family used to be across from us in Titusville Marina in the late 90's. It seems like a design technique that is not uncommon but I'm not quite sure if this is so. It look like it may be very thick darkened plexi or that other stuff..can't think of what it's trade name is...and that they are thru-bolted flush with some inset for the bolt heads to sit in on the outside of the porthole but be covered over somehow to appear flush and basically the same color as the tinted perspex or plexi...perspex..was that the name? Anyone who can enlighten me here...I'd appreciate it as I want to use this system on my Hunter 20 upgrade if I can...it appears simple and strong ...but I could be wrong...not to make a rhyme, but it seemed like the time..etc etc..
  #128
Old 12-11-2009, 12:36 AM
boat fan's Avatar
Rep: 357 Posts: 679
Are you thinking of Lexan , soulgour ?
It`s strong but soft ...( scratches ).
  #129
Old 12-11-2009, 02:53 PM
Rep: 146 Posts: 334
lexan...It could be...scratches easily?...scratching potential is a major downside to that type of installation..especially on my boat where there is not much room on either catwalk forward...hmm...scratch that idea...
  #130
Old 12-11-2009, 03:16 PM
Rep: 443 Posts: 925
sandwhich the lexan between plexiglass
  #131
Old 12-21-2009, 08:32 PM
kayaker50 kayaker50 is offline
Rep: 39 Posts: 33
Troy2000, have you done anything more with the model? I've spent the last couple of weeks looking over all the links posted here as well as googleing and binging wooden sharpie etc.
I'm particularly interrested in your cabin- how much headroom can you get while keeping the good looks of a traditional sharpie. Here is a photo of one I really like made from Woodenboat's Egret plans (modified) in North Carolina with a slightly higher cabin: http://www.woodenboat.com/wbmag/laun...S_Entry_id=224
Chip.
  #132
Old 12-22-2009, 12:48 AM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1578 Posts: 1,153
Chip.
I haven't had much time to mess with it, k50. Between working my regular shifts, covering for guys on vacation, driving home and back on my days off, handling the honey-doo lists at two separate houses (our own and the one we just inherited from my mother-in-law) and everything else that comes up, I'm getting a little frustrated. It's something you can't really just sit down and knock out a few minutes at a time, unless you're following someone else's detailed plans.
But I've messed with it enough to prove (to my own satisfaction, at least) that you can get a decent sheer and a proper bottom with straight-cut sides, by manipulating the beam and the flare. What I have now is basically just the sides wrapped around four temporary molds, brought together at the stem and ending in a transom at the other end. The molds at each end are set where I plan to have actual bulkheads to create water storage and flotation compartments, and the other two are set at each end of the future centerboard trunk.
By tweaking those four molds, I've come up with the recommended flat run in the bottom, for the first third of the waterline length. There's a gentle rocker in the middle third. The final third is almost straight, but not quite; it has a little bit of rocker in it. I'll settle for that....considering that we're looking at a maximum 8 or 9 inches of draft anyway, I doubt it'll slow the boat much.
Now I need to start laying out the actual bulkheads and frame members. It looks like I'm going to be stuck away from home but not working the next couple of days, so hopefully I can make some progress. I may cheat and leave the chine stringers out, to simplify and speed up construction.
There's a difference between keeping an open mind, and letting the wind whistle between your ears...
  #133
Old 12-22-2009, 01:00 AM
troy2000's Avatar
Oh....the headroom question. I'm going for decent sitting headroom in the cabin, and that's it. I'm not even going to try to push the envelope; it'll probably be something like four and a half feet.
Remember, I'm building this for the Colorado River lakes, which are surrounded by desert. I'm not really figuring on needing much in the way of being able to hide from the elements. I can't run a big enough air conditioner to fight the summer anyway, and the winters aren't so hard I need to hole up inside. Most of our waking time will be spent in the cockpit, or on the beach we've grounded the boat on.
  #134
Old 12-23-2009, 07:03 PM
Boston's Avatar
Boston Boston is online now
Rep: 1360 Posts: 3,257
hows these Sharpies do as coasters
I'd think they would slam like crazy and knock the stuffing out of the crew in anything other than glass water
my old sailfish was basically a sharpy and its small size lent a lot to its comfort at least for me as a kid
but at say 30'
whole other story I would think
one good storm and I would think you would blow the bottom right out of it coming off the first big wave
my guess is your limited to clear skies and smooth sailing or am I missing something. I've never sailed a larger sharpie.
B
I am skeptical of the deniers diatribe
  #135
Old 12-23-2009, 07:58 PM
troy2000's Avatar
but at say 30'
B
Yes, you're missing something. If that were true, the use of sharpies wouldn't have spread from Connecticut to Florida. Sharpies are actually very seaworthy boats within their limits, and I've never heard of one 'getting the bottom blown right out of it coming off the first big wave'--particularly since that's the strongest part of the average sharpie....
To begin with, a sharpie is just that: long and narrow. It isn't going to act like a skimming dish or a scow, when it gets into rough water.
There is a case on record in which a tonging sharpie rescued the crew of a coasting schooner at Branford, Connecticut, during a severe gale, after other boats had proved unable to approach the wreck.
And your sailfish was nothing like a sharpie. You can't really compare a sailboard that you're sitting on top of to a 30' sailboat with several thousand pounds of displacement....
The Perfect Sharpie Brasstom Boat Design 15 03-23-2011 01:04 PM
Looking for comments on 30' sharpie concept davesg Boat Design 4 11-05-2009 03:21 AM
Sharpie; Opinions, please... srt9969 Boat Design 2 05-16-2009 04:06 AM
Sharpie Plans mkrautha Boat Design 0 11-20-2008 09:53 AM
Sharpie on Duckworks Florida_mariner Wooden Boat Building and Restoration 0 03-21-2005 10:42 AM
