30' plywood sharpie
Discussion in 'Boat Design' started by davesg, Nov 4, 2009.
  1. GTO
    Likes: 9, Points: 18, Legacy Rep: 101
    GTO Senior Member
    I spent an indeterminate time in a very little room once. Minutes? Hour or so?
    My knees were crushed into my chest and my face shoved into my kneecaps.
    Another time the room was about 3'x3'x3'. That was about 12 hours. We weren't suppose to sit down, but I managed it.
    Some people ended up screaming.
    All for a good cause though. :) :( :) :( :) :( :) :(
    Thats why my next little boat will have a box keel. I WILL have comfortable sitting!
  2. troy2000
    troy2000 Senior Member
    If you figure out how to hold the draft of that box keel to about 8 inches or less, let me know.:)
  3. Angélique
    NIS 23 interior looking aft.
    BTW, this isn't bad for a 23' sharpie. But where to put your legs? And it looks like the guy can't sit back!
    Or for those who don't want to sacrifice very low draft............ leeboards?
    You always have to compromise something, certainly in a sharpie. :)
    Good Luck!
    Angel
    PS - Troy, get some right scale puppets in the model to have a real idea how it looks!
  4. troy2000
    I don't like those bolts sticking through the cabin roof; looks like they could be painful if you weren't wearing a bump cap.
  5. ancient kayaker
    Likes: 147, Points: 0, Legacy Rep: 2291
    ancient kayaker aka Terry Haines
    With that tumblehome, narrow beam and centerboard trunk, wouldn't it make more sense to arrage some (at least) of the seating fore-and-aft?
  6. troy2000
    I believe the settee he's on is fore-and-aft; he's just turned sideways because his knees don't fit between it and the centerboard.
    Looks like the picture was taken from the forward end of the vee-berth.
  7. ancient kayaker
    I meant the sitter would be fore-and-aft not the seat. That is just a berth with a nod to sitting. With a pivoting section for a backrest and a drop-down section for the lower legs it could be far more comfortable. Of course, then the owner would want to furl the sails and proceed under power, so maybe comfort is not the way to go!
  8. troy2000
    Some interesting thoughts there. I've been mulling over the seating problem myself; thanks for the input.
  9. apex1
    apex1 Guest
    Do´nt know where the guys dumb grin is coming from (maybe they told him he must sit there just for a minute), but I know that you should´nt bring your dog below deck on this boat!
    That would be named cruelty to animals.........................
    Regards
    Richard
  10. Boston
    Boston Previous Member
    agreed Troy
    someone will surely impale themselves on those bolts
  11. hoytedow
    Cut a rubber ball in half and jam it onto the bolts.
  12. troy2000
    If you look closely, there are entire lines of them. I'd have put lengths of wood backing with beveled edges, and been done with it.
  13. ancient kayaker
    The beamwise rows are close to the beams and safe enough. The fore-and-aft rows look like they are holding rails. I would be tempted to pop them off and look around for a more appropriate style of fastener, smooth and as flush as possible.
  14. Angélique
    I'm glad I posted the NIS 23 interior pic, it gives a lot to talk about :D
    And Terry, thanks for the chair tip . . . . . :idea:
    Good Luck!
    Angel
  15. ancient kayaker
    You're welcome! I just took the garden loungers out of storage and had an aha moment. Usually I get senior moments ...
