Old 03-09-2004, 02:01 AM
Andrea Gail Andrea Gail is offline
Rep: 10 Posts: 7
2D to 3D, possible?
In Autocad 2002
Is it possible to transfer a 2D print into 3D ?
If you got all of the views....
Old 03-09-2004, 09:34 AM
CGN CGN is offline
Rep: 138 Posts: 547
Yes, raster to vector, taking dimensions form the blueprints, importing the actual picture of the blueprints and tracing on top of the image in autocad.
Old 03-09-2004, 10:13 AM
Rep: 10 Posts: 7
I tried to use the prints as templates and cut away parts from a block.
But it didnīt wotk out very well
Old 03-09-2004, 10:48 AM
CGN CGN is offline
Rep: 138 Posts: 547
Ok, involves lofting and fairing, the fact that you are tracing from the blueprints it won't warranty that the hull is fair itself, i should mentioned before, could be that the linea are not fair, or intended for construccion, or if you try to just trace in top of the blueprint in autocad and not fair again to check that everything matches it will be worng at the end for sure, is not going near to construccion.
you must fair again after you traced the blueprint in autocad.
There is other software like rhino that can do do that and check for fairness but you can do it in autocad, just go trough the lines and fair
3D Rhino model and 2D drawings signum Software 2 08-19-2005 06:35 AM
3D v 2D guest12020101217 Software 10 03-24-2004 06:33 AM
CL 2d to 3d nico Sailboats 3 02-04-2003 10:45 AM
