Old 09-04-2009, 05:26 PM
Davesea Davesea is offline
Rep: 10 Posts: 8
23' panga with open bilge design
Here are some photos from a boat designed with an open bilge with a grate over it. Any water entering over the gunnel will drain to the center of the boat into the bilge. two bilge pumps will evacuate the water. Bilge is always accessible and visible. Lots of storage too and holds my 9' rowing oars.
Flotation is in the forward half of the bow platform, side seats (except for the small compartments with hatch) and in the stern side boxes. Sealed compartment floation is filled with 4" styrofoam cut to fit and coated with epoxy resin.
decks, transom and internal structure are Coosa board.
The boat is awesome in a chop, cutting through the waves. The more weight the better. I tow the rig with my Volkswagon Passat 4 cyl turbo and it does just fine. I use a tilt keel roller trailer which gives me access to most ramps here in the PNW that most other boaters can't use.
The bimini encloser makes a cozy, lightweight cabin.
Any comments?
Dave
23' panga with open bilge design-dscn3457s.jpg  23' panga with open bilge design-img_3181.jpg  23' panga with open bilge design-img_6925.jpg
Old 09-05-2009, 07:13 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
They look like fun boats.
Gary
"The hand feeds the mind."
Weston Farmer
Old 09-08-2009, 06:58 AM
Village_Idiot Village_Idiot is offline
Rep: 75 Posts: 238
Are there scuppers above the deck / waterline? Don't rely on bilge pumps, as even a half-dozen of them won't keep up with a coupla good-sized waves coming over the gunwale. They are good for maintenance drainage, that is it.
I like Pangas, they are a good design. Although I think the Americanized versions are getting way too fat. Even many of the imports are still too wide for my personal tastes. But, they are better than much of what is out there...
Old 09-08-2009, 01:30 PM
Rep: 10 Posts: 8
No scuppers
I guess it depends on what you are relying on the scuppers or bilge pumps to do.
The open bilge design is more concerned with stability than evacuating water. No scuppers I have seen, on 20' size range outboard boats, are capable of evacuating a couple of good size waves before the boat will become unstable and possibly capsize.
So in the open bilge design the water from the two good sized waves go to the bottom of the hull rather than on top of the deck so the stability is better than a sealed deck.
I agree the Americanized versions aren't really using the Panga narrow beam design. It is mostly for marketing I guess. What did you mean by "But, they are better than much of what is out there..."
Old 09-09-2009, 07:35 AM
Rep: 75 Posts: 238
Don't get me wrong, I like the open bilge. It is just that too many people rely on bilge pumps to do what they were not designed to do - i.e., pumping lotsa water quickly.
I meant that the overall Panga design is better than many of the other boat designs out there, speaking of open-bow 20- 26-foot outboard rec boats. Most are too fat, or designed to do just one task well. I am a multi-tasker, and the Panga is a multi-tasking boat. I myself run a custom aluminum boat that utilizes a hull design concept not unlike a Panga.
Old 09-09-2009, 11:06 AM
Rep: 10 Posts: 8
I agree, nothing is really going to pump lots of water quickly but with the open bilge design that is not really a requirement. With bilge pumps, hand pumps and buckets the boat can be slowly bailed without having to worry so much about capsize. Although I was impressed the the two pumps bailed the swamped boat (showed in the photos) in 20 minutes.
I would really like to see an aluminum panga, I was hoping someday someone could copy the pictured hull in aluminum including the lapstrake. Would you post some photos of your boat?
Old 09-09-2009, 11:18 AM
Rep: 10 Posts: 8
Fun boat
Gary,
This is a fun boat, I have used it for all sorts of things from hauling trash off beaches during beach clean ups, to moving gaggles of kids, to freediving. From San Juans to Hood Canal to Neah Bay. I plan to cruise up to Port Townsend this weekend to check out the wooden boat festival.
Dave
Old 09-09-2009, 12:42 PM
Senior Dreamer
Hi Dave,
Re: Port Townsend Wooden Boat Festival
I’ll be there most of the day Saturday. Dock space will be nonexistent if you don’t have something reserved already. I would love to see your boat, if I see it I’ll give you a shout. The weather should be nice so there will be a good turnout.
Gary
Weston Farmer
Old 09-09-2009, 03:19 PM
NOTURS NOTURS is offline
Rep: 10 Posts: 19
A friend of mine is rebuilding a 27 panga from Mex. He has been told that they tend to get tippy, what are your thoughts on this?
Old 09-09-2009, 05:06 PM
Rep: 10 Posts: 8
Tippy Panga?
The panga pictured is actually from a Trinidad design and they call it a Pirogue. IE canoe. So Yes Panga's are tender and will wobble under your feet which is a good feeling since it feels like a boat. My previous boat was a BW 18' outrage, total opposite boat. It was heavy, wide beam, required lots of HP (and fuel) and pounded in seas, but it was not as tender, not nearly. That seems is what most US boater want is a stable boat at anchor, so they feel like they are sitting at the dock?
Just because the Pangas are tender though does not mean they are less seaworthy. These boats service third world fishermen all around the world in all kinds of seas and they do it safely and efficiently. It would be helpful if some first world engineers would do the calculations to characterize their advantages.
Old 09-09-2009, 05:16 PM
Rep: 10 Posts: 19
Thanks for the reply Davesea,
My friend in question wants to know if his would be able to handle area of 3,000 ponds of fish. I have seen some pic's and read some articles ref- "fisherman from other countries " , with heavy payloads, no disrespest intended, but they also did not have shirts, shoes, and I beleive a couple of them had kids strapped to there backs. While pulling in many lengths of net!
Do it right Do it light, Do wrong Do it long
Old 09-09-2009, 05:22 PM
Rep: 10 Posts: 19
This would be nice
There has been a blow up of panga style boat in S-Fl area. andros is just another
The flooded pic says a lot, I like it
Old 09-09-2009, 05:59 PM
Rep: 10 Posts: 8
I am not expert, but a 27' panga and 3,000 lb payload should be no problem. My 23' would easily handle 2,000lb. If he is going to have a huge payload, make sure he doesn't put a deck in the boat. Floor boards would work well and it would allow him to store his fish as low as possible when He had a large payload. Now tell me where this guy is going to catch 3K# of fish.....
Old 09-09-2009, 06:43 PM
Rep: 10 Posts: 19
Roe Season Almost here!!!!!!!!!! Thanksgiving day
14' 26 lb cast net
Old 09-09-2009, 09:12 PM
Rep: 10 Posts: 8
Just remember, it takes mullet to make mullet
Water logged 23' Tsunami open fish Capt Mac Boat Design 18 01-25-2011 07:48 PM
Exploder-Extraordinary 23' Tri Design Doug Lord Multihulls 2 03-27-2007 07:17 AM
Interior design for a 23' tiller skiff Davesea Boat Design 0 11-09-2006 06:55 PM
Panga Boat Design Pangalover Boat Design 8 05-18-2006 08:49 PM
Volvo Open 70 Design woody_paul Boat Design 0 12-08-2004 02:07 PM
