  #31
Old 01-24-2011, 10:58 AM
garrybull garrybull is offline
Rep: 10 Posts: 49
little update. i know its been a while. my mate has done a quick 3d drawing which he printed of for me. i have got to get him to make some small modifications to the final drawing. i will have more pics soon on a disc so will be able to upload proper pics ok.
what do you think of it so far.
  #32
Old 01-27-2011, 05:22 PM
MooringProJeffL's Avatar
MooringProJeffL MooringProJeffL is offline
MooringProJeffL
Rep: 22 Posts: 7
The hulls look asymetrical so there could some crusing affects that you should look into. My work barge has 30 inch diameter asymetrical pontoons with narrow centered bows. While cruising at 12-mph, the water level between the toons is 10-inches higher than on the outboard sides. The faster catamaran power boats have vertical sides on the interior. There may be a difference in efficientcy with different hul shapes and speed.
Jeff Lefebvre
Three maritime patents
www.NewEnglandMooring.com
  #33
Old 01-27-2011, 07:32 PM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 710
Sponsons look symmetrical to me, from that pic. That seems to be the accepted norm for all round usage, I don't think he wants a speed demon.
  #34
Old 01-28-2011, 12:12 PM
Rep: 10 Posts: 49
not after doing 50knots. if it will do 30knots i'll be chuffed to bits. cruise at around 22knots. both hulls are identical. i have got to make a couple adjustments to the final drawing yet. hopefully will have finished hull drawings done soon. as soon as i get them on a disc i'll upload them on here.
  #35
Old 01-28-2011, 05:42 PM
Rep: 246 Posts: 710
Hard to tell from that view, but my first impression was the bows are a bit too full, going on what I have seen in proven vessels, I'd have probably gone for a deeper vee with a triangular pad at least 9 " wide at the transom, and sharper bows, but what you have seems workable.
Power Catamaran Design DHMzip Boat Design 8 11-06-2010 07:06 PM
Small power catamaran bsmit24 Powerboats 18 11-10-2007 09:01 PM
Power / Sail catamaran vectorges Boat Design 2 04-22-2004 02:20 PM
Power Catamaran Guest Boat Design 3 01-30-2004 08:36 PM
Plans for power catamaran bobo Boat Design 2 12-11-2003 10:57 AM
