Old 12-02-2006, 12:40 AM
thelonius thelonius is offline
22,000 lb displacement + Tiller?
Hi All
Thinking about replacing Edson worm steering with tiller on our boat.
Boat is a Union 36 -- 22,000lb displacement, long keel, skeg hung unbalanced rudder.
For pictures of our boat -- refer www.thelonius.com.au
I'm looking for examples of similar boats where a tiller has been successfully used.
Alajuela 38s have tillers, but rudder transom hung. I'm told there is at least one Tayana 37 with a tiller and a happy owner...
Will have autopilot with below deck linear ram.
I think we'll be okay, but we're at the high end of displacement for tiller.
Other option is Edson CDI pedestal steering.
Both options have advantages and disadvantages. Compass/binnacle and engine throttle control will have to move. And some mods to cockpit to fit tiller on rudder stock.
I'm estimating a tiller length of about 1700mm from centre of rudder stock.
Comments, suggestions welcome.
Regards
Jon
'Thelonius'
Melbourne, Australia
Old 12-02-2006, 05:46 AM
Rep: 700 Posts: 3,208
We built a 33x28x10.6 offshore cruiser with 16,251 designed disp , that runs over 20,000 RFS with 737 sq ft of working sail.
The tiller is 4 ft and a cheap tiller ram autopilot does just fine.
An Aries vane gear is used for deep ocean work , as downwind it compensates for waves from astern better than the electric unit.
The Aries anticipates the stern swing , the electric can only steer AFTER it has happened.
FAST FRED
Old 12-02-2006, 06:30 AM
fcfc fcfc is offline
Rep: 333 Posts: 680
Pen Duick VI , 73 ft, 70 000 lbs, skipped by Eric Tabarly had a tiller. Not a wheel.
Old 12-02-2006, 07:17 AM
QC3 QC3 is offline
Rep: 10 Posts: 5
There was a Swedish 12 Meter back in the 70's that was fitted with a tiller. I have a firend with a 44' IOR boat with a tiller. I took a day sail on a toursit-type replica 18th century bark (approx. 90' loa) that had a tiller (with block and tackles on each end to help). I know plenty of folks who would love to throw out their wheels and go back to a tiller arrangement. I think the whole key is just the length (i.e. lever arm) and how much room you have to swing the thing without totally having to redesign your cockpit working space. You will lose workable crew area because the helmsman needs that clear arc to swing the tiller. Other than that, go for it!
Best Foil Shape for Rn 250,000 to 750,000 Guest Sailboats 9 08-03-2010 04:05 PM
Interior design for a 23' tiller skiff Davesea Boat Design 0 11-09-2006 07:55 PM
26' westerly $14,000 call yhxaig Marketplace 0 07-23-2006 03:12 PM
Tiller, Kitchen rudder duluthboats Boat Design 4 09-09-2003 07:16 AM
shorter tiller -same power -more room scotto Sailboats 4 10-29-2002 05:41 PM
