Old 08-28-2005, 11:42 PM
jackason jackason is offline
Rep: 10 Posts: 11
21' small tugboat plans
Hello,
Somehow I just delete this post by accident so here is condensed version repost, again.
I was wondering if anyone is building, has built or owns any of the 21' smalltug series of boats designed by Mal Low. After looking at many designs for small workboat, small trawlers and such I came across the smalltugs.com website.
Anyway I ordered and received the study plans which were excellent and more informative than most other project plans I've received in past.
I really like the concept of a compact workboat, my wife say I really like it because it's a tractor on water, she is partially correct.
I'm pretty sold on the 21' single chine "pouch" tug. I have the skills/tools to build in any of the designer suggested materials - FG, Pre-Lam, Epoxy Ply, Alum. and Steel. I'm leaning towards steel for a few reasons but heard it isn't a good choice for boats 30' and under? I'd like to hear others opinions in general before I commit to ordering a full set of plans.
thanks -CJ
Old 09-02-2005, 05:09 PM
Littlebearcanoe Littlebearcanoe is offline
Rep: 10 Posts: 7
Hey cj. I would like to see them plans. What about cedar strip with bead and cove strips with fiberglass?? You can use 3/8 thick strips. And lay it up ?
Later
Old 09-03-2005, 12:14 AM
Bern Bern is offline
Rep: 10 Posts: 15
A workboat?
Hi cj. --- I’m just curious as to your future plans and use of such a vessel. Is this going to be a workboat, or a neat, beautiful, and something different, craft to cruise around in? I think it would be great to have, as it is not “Just another boat”. I am building a 19 footer that is not what is normally seen on the water, and think it is great to see other boats on the water that have “Personality”. Good Luck!!!
Old 09-03-2005, 04:42 PM
Rep: 10 Posts: 11
yeah, I'm somewhat surprised there isn't more interest in workboats this size or at least that seems to be judging from all of the plan offerings I've seen so far.
As far being used for a workboat I doubt that sorta, I'm looking more to explore the new england (and then some) coastline and go up some riverways, that kinda stuff. This boat just seems to find the bill. If I build it I will outfit it as much as for work as for pleasure as my budget would allow. I'm a strong believer in form follows function, besides I don't need to go 20+ knts to enjoy the water.
What I really wanted to build originally was a sailboat something much like the GlenL 22' Amigo. There aren't many plans out there for a trailerable sailboat like that one. and my firsthand sailing experience is limited, I've had a hard time figuring out what the learning curve would be to sailing a boat that size the first time around. But with fuel prices getting higher and higher I haven't ruled out a sailboat entirerely.
-CJ
Old 05-13-2007, 12:59 PM
oceanvoyager oceanvoyager is offline
Hi CJ
I have bought plans from Mal Low and shall start building in a few days. I like the idea, the design, the whole thing. The instructions are good and although I haven't built in steel before, I think that with a few little grey cells working and Mal's good advise I should be able to produce something resembly what he designed.
I bought the 27 foot double chine workboat becasue that is exactly what she will be.
Rich
Old 05-16-2007, 08:29 PM
Lafitte Lafitte is offline
J. Delgado
Rep: 15 Posts: 8
Steel under 30'...
Small steel workboats are quite common in the offshore oilfield industry, as
is of course, aluminum. We cut them on our cnc plasma system daily.
Weight is everyones primary concern, but the numbers allow for steel hulls
as small as 16' IF you can weld it properly.
The main difficulty for most amateur builders is the ability to properly weld
light guage steel.
For all light weight steel craft with plate thinner than 12 guage steel, we
generally use aircraft grade gas welding equipment. This produces much less warpage, and does a great job.
When you're slamming into unknown submerged objects, there's nothing
quite like steel.
Best of luck
Lafitte
Old 05-24-2007, 05:59 AM
MarkC MarkC is offline
Rep: 13 Posts: 196
Ken Hankinson and Al Sorenson's small steel tugboat plans are back up on the GlenL site after dissapearing when the Hankinson boat plans site was closed.
They use light-guage-steel in a 'shrink to fit' system.
http://glen-l.com/designs/hankinson/fredmurphy.html
http://www.boatdesigns.com/departments.asp?dept=718
Old 01-21-2008, 12:15 AM
harry tams harry tams is offline
Rep: 10 Posts: 34
Hello. Re: Mal low designs, I too have had plans for about a year. Still a bit undecided. 'Paunch 21, Pouch21. Also considering Mr Low's Porker 27. Is anyone building presently? Have any of these designs been completed? Thanks
Old 07-22-2008, 03:53 AM
nezih ahmet nezih ahmet is offline
Rep: 10 Posts: 9
Dear Sir,
I am interested in Tugs.Do you have cpowder Puf 21Ft designs?If yes I want to ask few .
Nezih
Looking For Small Fishing Boat Plans Alum. PDH Boat Design 3 03-21-2005 08:56 PM
seeking for boom plans small boat 10 fts. javier Boat Design 0 03-11-2005 06:52 AM
Looking for plans to make small sectional barges Joseph Boat Design 1 09-03-2004 02:17 PM
building a small sailing/rowing dinghy need plans Jeffrey Ashe Wooden Boat Building and Restoration 3 08-19-2004 03:43 PM
Looking for plans to make small sectional barges Joseph Boatbuilding 0 08-12-2001 06:47 PM
