Old 11-14-2010, 12:01 PM
Mojito Mojito is offline
Rep: 10 Posts: 6
21 Mt Oil And Garbage Collector / Help Needed
Hi ,
This a school project that i have to design of the hydraulic crane, lifesaving appliances, electronics and aerials .
All 3 things have to be under lloyd limitations .
I uploaded the GA plan of the boat .
I really have no clue where to start . I appreciate for your opinions helps .
Tech Specs .
OIL AND GARBAGE COLLECTOR / BOOM PUTTER VESSEL
Length o.a. 21.50 m
Length b.p.p. 19.20 m
Beam 6.00 m
Depth 2.50 m
Draught (design) 1.50 m
Draught (scantling) 1.50 m
Deadweight (at scantling draught) 50 tons
MCR (option 2) 2x261 kW
MCR (option 1) 2x313 kW
Speed (at design draught)(option2) 9.0 – 10.0 kn
Speed (at design draught)(option1) 8.0 - 9.0 kn
File Type: dwg OSRV_GeneralArrangement_SRS_23OCT10 (1).dwg (2.20 MB, 24 views)
File Type: dwg OSRV_GeneralArrangement_SRS_23OCT10.dwg (2.20 MB, 25 views)
Old 11-14-2010, 12:49 PM
Rep: 1493 Posts: 7,447
I can't open the attachments. If they have what the title says, start by trying to satisfy each requirement. Then see how they interact and what compromises you need to make. What level of school are you in? Did they teach you the design spiral?
Old 11-15-2010, 01:00 AM
nikezz nikezz is offline
Rep: 12 Posts: 35
This might help you.
http://www.np.edu.sg/coi/mot/project...20Garbage.aspx
Mining the Great Pacific Garbage Patch wellmer Boat Design 55 11-15-2009 05:44 AM
Cheap garbage barge design - Cambodia mackhina Boat Design 12 08-13-2009 08:05 AM
electric oil pump for oil changes and priming simon Diesel Engines 13 11-14-2008 05:54 AM
Oil? Dan Currie Sterndrives 1 08-14-2007 11:27 AM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 05:43 PM
