Old 01-29-2005, 07:54 PM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
20 nautical miles...
Hello...
OK - Gibsons is about 20 nautical miles by water from where I now live (OWN A CONDO)...
So to get to work in one hour I need to cut 20 to 25 knots in all weather and maybe thru an odd 3 foot short chop...
I need an outboard cabin cruiser to do same...
I am just fielding this to see what you guys come up with for links and ideas...
Lets say no more than 20 feet LOA - 25 knot tops - good deep vee - welded aluminum or ply - developable surfaces - absolutely dead simple to build...
Cheers...
SH.
Old 01-30-2005, 03:37 AM
DaveB DaveB is offline
Rep: 11 Posts: 128
25 kts through 3' chop
not exactly a cruiser, but to do 25 kts through a 3 ft chop n' keep your kidneys together might be the ticket...
http://www.diogenemarine.com/pictures/testing_6_5_m.MPG
http://www.diogenemarine.com/testing65m.html
Cheers,
Dave
Old 01-30-2005, 04:45 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1544 Posts: 1,138
Mighetto may just come up with some clever idea. A chopped version of his beloved mac26x perhaps...........
Imagine Sean, you can motorsail at 20 - 25 knots, best of both worlds
Wynand
A scatterling of Africa
Old 01-30-2005, 10:38 AM
Funny...
Hello...
I figured someone would hit upon Diogen or Kurt Hughes bits...
It is intrigueing - but I think a bit of another side track diversion...
I will put that in my 'fiddle file' - although I only need to show up - don't have to haul tools or welding machines - hmmmm....
Today is Sunday - I no longer work shift or call outs - I guess I am allowed to 'fiddle' - yes...
Thanks...
SH.
Old 01-30-2005, 03:21 PM
Richard Petersen
Alaskan jet drive boats. O/B versions have no heaters-- I/B or I/O have a built in hot water heater built in for the cold stuff. plus it is more fun to work on them than the O/B in a chop.
Old 01-30-2005, 07:36 PM
mattotoole mattotoole is offline
Rep: 10 Posts: 197
I've met a couple of BC water commuters with boats like that. My faves are the aluminum Eagle Craft with jet drive. Logs? Phooey!
Old 01-30-2005, 07:41 PM
Richard Petersen
Sean, is floating junk a problem ?
Old 01-30-2005, 09:33 PM
Richard Petersen
3' chop is more than a 20' wants to see with the wind from the WRONG commuting direction.
Old 01-30-2005, 10:09 PM
CGN CGN is offline
Rep: 121 Posts: 547
Sean, right in Gibsons there is a local company that builts aluminum boats, you can probably get on contact with them, and talk about what you are looking for.
you can contact Jeff Rhodes
Coastal Craft
Welded Aluminum Boats Ltd.
1038 Venture Way
P.O.Box 860 Gibsons BC Canada V0N 1V0
Phone: (604) 886-3004 FAX: (604) 886-4537
Old 01-31-2005, 05:18 PM
Richard Petersen
Sean, are you buying or building ? not to sure ?
Old 01-31-2005, 08:06 PM
I would build...
Hello...
It is Coastal Craft that wanted to hire me...
Currently working for Bracewell Boatworks...
I am just now designing a deep vee garvey type hull for same - much like the commuter in my gallery - lost files to a hard drive crash...
I will weld in good thick aluminum - yes dead heads are a problem...
SH.
SH4431 - Marine Assistant (Nautical), Permanent Mark Charman Services & Employment 0 05-27-2005 12:23 PM
Press Release: Nautical Structures appoints NonStopYacht as European representatives Polarity Press Releases 1 07-04-2003 05:30 PM
world records kicka$$ Open Discussion: All Things Boats & Boating 13 12-20-2002 05:51 AM
boats.com top 20 list Scott Sailboats 0 10-30-2001 05:47 PM
boats.com top 20 list Scott Powerboats 0 10-30-2001 05:44 PM
