  #31
Old 03-05-2009, 10:24 PM
explorer3114 explorer3114 is offline
Rep: 10 Posts: 9
Drain plug
I use a 1/2" live well plug for my Clipper. Works great.
  #32
Old 06-13-2009, 04:08 PM
chevynut chevynut is offline
My new Clipper
I just bought what I believe is a 1958 16' Orlando Clipper. Owner does not have the title and I am in the process of getting one thru the state.
I have a couple of questions that maybe the people in here might help me with.
Is there a way to tell what year model it is?
Is there a VIN, serial # or some type ofnumberassigned to each hull? Location if such exist.
If anyone has one similar, do you now the max HP?
I know this is request is a long shot, but does anyone have a windshield?
Thanks in advance, and hope to be on here a lot.
Mike
1969 orlando clipper-100_1389.jpg  1969 orlando clipper-100_1390.jpg  1969 orlando clipper-100_1392.jpg
  #33
Old 07-16-2009, 10:54 PM
scenic scenic is offline
Rep: 10 Posts: 3
Clipper Boat Plug
[I think I found a solution by using a PVC 3/4" threaded adapter to a 1" slip fit. By placing an O-Ring over the threads and a 1" PVC slip plug glued to the 1" slip fit side of the threaded plug. The 3/4" to 1" provides a wide flange to compress the O-Ring to seal it.
  #34
Old 10-30-2009, 10:04 AM
maxh maxh is offline
Originally Posted by scenic View Post
I acquired a used Honda 15 four stroke with a 20" shaft. http://www.boatdesign.net/forums/att...1&d=1234361544
Hi there. I am looking at buying one of these engines.
Can you tell me please if the Honda 15 (the one shown in the picture) has a tilt tube ready for cable steering and if you had to buy any more parts to accomodate the steering.
Also, what Honda control box are you using? Is this engine compatible with most honda side control boxes? Was it easy to link up to the engine?
How did you go about relocating the kill cord to the control box?
Many thanks for your help.
  #35
Old 11-01-2009, 09:50 PM
Rep: 10 Posts: 3
You may have to use an engine adapter to raise the 20" shaft up to prevent too much drag when it is too deep in the water. I have one installed on the picture you looked at. If your transom is 20 " there is no need.
I used a Honda steering kit which came complete with all easy bolt on parts to hook up tele-flex steering to. I purchased a Honda control box with built in ignition and electric choke. It also has a built in kill cord that comes with it. I think that there is a control box below the model I chose that does not come with the ignition switch built in. I would recommend one with the built in switch. The instructions and diagrams that came with the kits made it pretty easy to install. The shifting cable and throttle cable have to be ordered to length and require an extra loop of about a foot to accommodate the steering movement.
Here is a link that may help you in finding the correct parts needed for your motor http://www.boats.net/
  #36
Old 11-11-2009, 06:39 PM
Tmartin56CLIP Tmartin56CLIP is offline
Rep: 10 Posts: 8
Jack plate for your motor you wrote about
Maxh,
I have a jack plate that would help you for that long shaft motor. I had a merc 700 with a 20'' shaft on my 12' orlando clipper and I used this jack plate to lift it high enough to get my moneys worth out of the motor.. This jack plate is simple and it works, I had it on craigs list for 50 smackers.. I live in orlando too, actually Altamonte springs. Here is my email, email me and I will send you some pics if you are interested... tm100@yahoo.com
Just got another Orlando Clipper a few months ago, a 16' 1961, Im puttin some serious work into this one and hopefully it will be as nice as my last one, the 12'. I sold it to another Orlando Clipper Enthuisast! Phyllis is in a god home now!!! Anybody interested in starting an Orlando CLipper Club? I will post pic's as soon as I can!
Yall take care!
16ft Tahiti (1969) pickled Powerboats 2 08-01-2008 01:18 AM
1969 Merc 650 MercMan69 Outboards 1 04-09-2007 07:12 PM
Seeking Anchorseal source in Orlando- Daytona area Turingengine Materials 0 12-12-2006 12:49 PM
Copper Rivets (1969) enahsx Wooden Boat Building and Restoration 1 11-20-2005 09:38 PM
Clipper Craft Terry Powerboats 0 03-01-2004 06:47 PM
