Old 09-07-2011, 02:16 AM
m3mm0s rib's Avatar
m3mm0s rib m3mm0s rib is offline
Rep: 31 Posts: 111
In each case http://www.youtube.com/watch?v=w4T3tx7Wi68
m3mm0 SR ib http://www.youtube.com/watch?v=5kwlNk7-iSg
Old 09-07-2011, 03:52 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Originally Posted by nacra5.8 View Post
..... Round bottom wise, I was thinking it's slightly more efficient, and making hard chines in DELFTship is kind of hard. I did a couple of experiments with the Carlson Hull designer, but it didn't seems as professional as DELFTship. ......
What you find easier to do with the software is a bad way to determine hull shape.
How much do you know about the fundamentals of boat design beside kind of being able to use some software?
Even though the USCG regulations on small boat load capacity, floatation, etc don't directly apply to a boat you build for your own use they are provide good guidance, particularly for a 17' boat to be used with 6 pasengers in 30 knot winds and a 3 foot "chop".
Old 09-07-2011, 04:14 PM
Rep: 3125 Posts: 9,395
Originally Posted by DCockey View Post
. . . . particularly for a 17' boat to be used with 6 pasengers in 30 knot winds and a 3 foot "chop" . . .
. . . and blasting along around 40 knots . . .
Old 09-09-2011, 08:22 PM
joelsimpson joelsimpson is offline
Rep: 10 Posts: 2
For comparison, I have recently designed and built a small planing boat after 40 years on the water. It is used in the Chesapeake bay and I run it at planing speeds of 13 to 32 Kts. The boat is 18' LOA moderate V forward and flat in the stern. Scantlings are 3/8 marine fir sides, washboards and combings, 3/4" bottom (double 3/8") except for the forward vee which is 3/8". The bow is decked back 4' to the 3" combing which goes back to the stern. Washboards (sidedecks) are 10" and are completely boxed in with 2" flotation all the way to the stern and under the forward deck. The stern is 1" cyprus sandwhiched between 3/8 marine fir. Chines logs are laminated marine ply. All joints are epoxied and fastened and have generous epoxy filets. Sides, and bottom 10 oz glassed in epoxy inside and out. All other surfaces glassed outside. Chines and stern joints have 3 layers of glass inside and out. This boat has been used for 5 years in good weather and bad, is incredibly stiff due to the side and forward decks and combing, and can take a beating. If I were to rebuild it, I would not reduce any of the scantlings.
Center Console Design Thano1 Boat Design 13 02-04-2009 07:32 PM
41 foot center console conversion kulas44 Fiberglass and Composite Boat Building 5 12-07-2008 02:38 PM
15 year old building 18 foot aluminum center console. bassboy1 Metal Boat Building 18 11-17-2008 07:13 PM
What are the costs involved in building a fibreglass 17 foot center console flats? Greasy Fiberglass and Composite Boat Building 2 08-13-2006 04:30 PM
Bertram 25 foot center console project ky87le Boatbuilding 21 02-18-2006 12:41 PM
