Old 12-16-2007, 11:06 AM
woodman's Avatar
woodman woodman is offline
11' tunnel hull
Scaleing down plans I found on the net and changing the look is more tricky than thought. Does any one know the depth and width of the tunnel in the Glen-l Tunnel Mite?
The only tunnel plans that have a pickle fork I found on the net is nearly 16' long.
Some of the pics. of current tunnels, the bottom side dosen't seem to curve up at the nose, the tunnel seems straight. Yet the sponsons get taller toward the front. And the top of the sponson is more wing shaped.
Trying to build an 11' boat to do 40mph with 25 hp outboard.
Any one have a set of Tunnel Mite plans they want to get rid of?
Avatar is my TNT with 650 kawasaki jet drive.
Old 12-16-2007, 12:12 PM
dick stave dick stave is offline
Rep: 12 Posts: 144
I'm not sure if this type of tunnel is compatible with a jet drive. If you look at the modern inboard tunnel jets ( Phantom sport jon, Seaark predator, Harbercraft extreme shallow ) you will notice some major differences. You may want to have a look at the Glen-l builders forum as there is an archived discussion regarding pwc powered boats.
Old 12-16-2007, 03:19 PM
Rep: 12 Posts: 144
I misread your post. Sounds cool. Carry on.
Tunnel hull questions Mrdennis Fiberglass and Composite Boat Building 0 07-11-2007 11:30 AM
F1 tunnel hull design Tore_M Boat Design 5 05-01-2007 06:00 PM
How to setup 12 ft tunnel hull Bill Kubiak Boat Design 3 08-03-2005 04:54 PM
Tunnel Hull Inflatables flyingdux1 Open Discussion: All Things Boats & Boating 0 12-14-2004 12:16 PM
tunnel hull midnightkayaker Boat Design 1 02-20-2003 09:49 AM
