| A 10m class steel hull radius chine sailing boat LOA:10.2m, Beam: 3.20m Draft 2.7~1.3m Displ. to DWL: 6000Kg |
| small modify LOA: 9.9m hull use 5mm steel plates. about 3200kg. cast iron ballast : 1400kg |
| hi, What is the gol of this post? |
| Not much lift from that keel strut. |
| Okay......... and then??? |
| Is this like a silent movie...but without the subtitles? |
| Good point John, but at least we should hear the Hammond organ! |
| Ah yes, that lovely organ ![]() |
| hi guys, I am back... It's a painful things that talk in English for me. So sorry for taciturnity. the boat displacement up to 7200KG(15900Lb). I add a little draft of hull. |
| I want to design a sailing boat. It is easy building for DIY, and have enough strength and durability in ocean-going. It is heavy and not very good highly faired. will slower than a glass fibre boat . But this is acceptable. Now, I feel that the boat is a little narrow when I check the room underdeck. perhaps 39' LOA is better... |
DoŽnt worry, that is valid for half of the Forum members too! Especially for those from the wrong side of the pond... But it would be nice to learn for what reason you show us your drawings. Are you a yacht designer or Naval Architect by profession? Regards Richard |
| radius chine == radius bilge ? | greenwater | Metal Boat Building | 9 | 12-14-2010 05:00 PM |
| Radius Chine Hulls | Inerested | Boat Design | 7 | 02-12-2008 08:04 AM |
| Steel-made hull with fiberglass-made radius chine ? | xarax | Metal Boat Building | 48 | 07-23-2007 12:35 PM |
| Steel-made hull with fiberglass-made radius chine ? | xarax | Boat Design | 0 | 07-05-2007 02:43 PM |
| Radius of strake and chine | jfblouin | Boat Design | 0 | 10-13-2005 11:33 AM |
