Old 05-04-2004, 06:46 AM
Will Will is offline
Rep: 10 Posts: 2
1) Are hulls same shape in a Cat 2) hull spacing
I'm thinking about building a catamaran... either power or sail.
My question is... are the two hull's identical in shape?
This would allow me to build only one mold.
ALSO - is distance apart important? I'm guessing that the eddies and currents from the bow cutting thru the water would make it important to have some minimum distance between hulls for best performance.
Thanks for any help.
Will
Old 05-04-2004, 08:13 AM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 394 Posts: 508
The two hulls are not necessarily the same shape, but most are.
The distance between the hulls is important, especially for a sailing cat. Larger distance = more stability, smaller distance = more resistance. But the distance can also be too large and make tacking difficult.
Anyway - before you can begin building, you'll of course need a design. If you buy one, these problems have probably been solved by the designer. If you want to do the design yourself, there are a LOT more things to consider, so I would suggest you find all the relevant litterature you can, and start reading.
Old 05-04-2004, 08:33 AM
Tim Bard Tim Bard is offline
Rep: 10 Posts: 6
Look at Compu-Craft for plans >>> ccplans.com
Col Clifford has a lot of designs and ~50 years experience.
He is a very clever designer
Tim
Old 05-04-2004, 09:28 AM
Yacht Designer
Rep: 394 Posts: 508
Oops - I forgot something!
Most sailing cats have symmetrical hulls, BUT most powercats have asymmetrical hulls!
Old 05-04-2004, 09:59 AM
Rep: 10 Posts: 2
Gee, I wonder why powercats have asymmetrical hulls and Sailing Cat's don't ?
I thought many of the Sailing Cats were also being sold as Power Cats... just by leaving the mast off... but what do I know
thanks for any additional comments - Will
Old 05-04-2004, 04:06 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 645 Posts: 1,723
Distance between the hulls also affects drag - bigger distance, less drag. However, bigger distance also = more structure needed for cross-beams, etc. You pays your money and takes your choice
Steve
Old 05-05-2004, 10:35 AM
guest
No one mentioned, the seperation distance of a sailing cat is the big factor for speed. THe cat can take huge sail area because the cg when loading a hull is way outboard. A hobie 16 has asymetric hulls, and I've heard it allows the boat to perform without a centerboard, a lead I have not investigated. Most hulls separation distances are limited by the 8 or 8.5 foot max trailering width mandated by the DOT.
Old 05-05-2004, 10:41 AM
guest
also, wrt some power cats, I have heard that assymetric shape has been used to lift water to a raised engine, like a tunnel hull allows a raised engine on flats boats. One usage.
How about boat design definitions JonathanCole Boat Design 55 01-24-2010 04:48 PM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
Wetted surface area - approximate formulas Mike D Boat Design 11 08-25-2005 11:00 AM
Stepped Hulls Ryon Macey Powerboats 53 08-01-2004 10:44 AM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-25-2002 11:26 PM
