Old 05-16-2009, 05:25 PM
icefang45 icefang45 is offline
Rep: 10 Posts: 14
wooden mast
i need 27'ft 5'' at base, spruce.i got that far its a gaff rig i have pics on boat design forum.if i knew what kind of boat it was it would be that much easier.but thats not to be and i want in the water now.i have the gaff and boom and old spruce mast which has to be replaced.HELP.wood is the main problem (spruce).im in B.C. so it shouldnt be a problem.i need plans.i plan on building my own from spruce. the wood seem to be my main problem.were do i find clean tight spruce.im a carpenter so i dont doubt my skill just dont know were to start.
Old 05-16-2009, 07:36 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
I doubt knowing what the boat's design is matters in terms of replacing the mast since no one will have that mast waiting on a shelf.
Better to copy the existing mast. If the mast was originally solid spruce, find someone to build a new mast from laminations of spruce. Fir can be substituted. It's a bit heavier, but fir makes a fine spar.
Your post is really a pain to understand.
Old 05-16-2009, 11:56 PM
Rep: 2891 Posts: 8,789
I'm not sure what you're asking Icefang45, but wooden spars are custom made, as Alan has suggested. If you need a mast, you'll have to build one or have one built. The third option is to see if you can find one of similar size and diameters. Considering it's a gaff, this limits your choices, so I'd start by calling boat repair shops and spar makers.
Old 05-17-2009, 12:48 PM
Rep: 10 Posts: 14
yes i was a little vague,im a one finger computer guy
Wooden mast??? Laser@pcrf.org Sailboats 8 02-11-2009 04:44 AM
Wooden Mast Repair MastSplit Boatbuilding 11 07-17-2008 01:26 PM
Help on Wooden Mast Head filiperosa Wooden Boat Building and Restoration 1 07-15-2008 08:41 PM
wooden mast wanaco Materials 8 07-05-2008 12:34 PM
Laminated wooden mast Audun Materials 5 05-22-2006 03:32 AM
