| Wood/Epoxy Beams or Foam/Glass Beams? It seems every time I try something "more advanced" out, I like it a lot better than the other way of doing things. Now, I am looking at the beams. On one hand, I can make them from plywood and sitka spruce framing. On the other hand, I could make them from foam and various glass laminations. Which would you want on your boat and why? My understanding of strengths are these: Wood/Epoxy: The Good- *Can withstand more cyclic loading without losing strength The Bad- *Good construction dependent on humidity *Complicated things like laminating sitka spruce together and affixing in patterns inside beams *May rot someday if I didn't do a great job with my epoxy coating *Heavier *Sawdust *I suck at working with wood and doing scarf joints Foam/Glass: The Good- *Easier to make - just lay out foam flat, cut glass layers to shape and infuse *Weighs less *Can be infused easily *Clean work The Bad- *Much more expensive *Plans call for lots of uni, but maybe I can substitute some triax and biax in. Which would you want on your boat and why?
__________________ "You can't solve all of life's problems with epoxy" - My Wife |
| If you have to buy more foam, you may get a better deal with a case price. I ruled out the use of wood for the above reason when I bought my foam. Whatever higher cost I payed could,nt have been that much if shipping were figured in, and I hope that little extra was worth the weight savings I plan on getting. rick |
| *Less weight has to be good, particularly for a cat. *at some point there's likely to be stuff screwed or bolted on, piercing your epoxy seal and opening the door to wet wood and rot. Maybe not a problem for you though as you know the risks. *Could you have some embedded aluminum sections to improve strength characteristics and reduce cost? ....welcome back. Any recent photos, how's it all progressing? |
| I guess it's unanimous. Nobody, and I mean nobody, on a couple of places I asked this question thought I should do anything but proper glass beams. I was leaning that way as well. Rick: Better prices on cases? I buy foam by the semi trailer load! ha ha ha Seriously, I think I got 6 double sheet cases last time. So yeah, foam/glass beams it is. Thanks for the input.
| Catamaran beams | bob the builder | Multihulls | 40 | 07-14-2009 05:29 PM |
| New Beams for my A Cat | Tinkersailor | Multihulls | 13 | 04-22-2009 04:14 AM |
| 7m tri beams | bushsailor | Multihulls | 21 | 03-03-2009 04:29 PM |
| Overhead trolly crain / wood beams | nero | Boatbuilding | 11 | 07-05-2006 09:33 PM |
| Roof beams | TONY B | Wooden Boat Building and Restoration | 0 | 06-06-2006 08:23 PM |
