| Windshield frame I'm new here so please be patient with me. Moving my open bow runabout out of the garage I snagged the top of the windshield frame on the garage door and basically destroyed one section of it. It is a fairly heavy aluminum extrusion with compound bends in it. Finding a replacement is proving to be pretty much impossible. I think that this member isn't so much structural as it is cosmetic. I have access to some CNC machine tools and a wire EDM (making an extrusion die?) but I have no experience with aluminum extrusion or how to recreate the required contour. Any suggestions? |
| I would replace the entire top exrtusion with a custom mahogany piece. I see the boat has some (fake?) wood trim already. I have done this before. It might be the best solution if you can't find an extrusion. I'm guessing the original pieces are bright anodized, and a custom extrusion would have to duplicate the finish as well. You'll go broke going that way. Either you get lucky and find the correct extrusion, or replace the whole top molding with matched pieces, or go with a wood replacement. I would go with the wood replacement, which adds to the boat's aesthetics in any case. Alan |
| That is a really interesting idea. Any suggestions on where to look for an individual capable of doing the work? I'd like it to look better than what I'm capable of doing. |
| I sure wish I lived closeby! A job like that would have to be done on the boat. I know no one in your area that could do it, though I'm sure there are a few. It should be laminated from thinner strips, glued with epoxy, and well sealed with epoxy and many coats of varnish. Maybe someone who trips across this thread. A. |
| 1990 Supreme windshield | Toolmaker1045 | Powerboats | 2 | 08-02-2007 08:00 AM |
| Windshield help | isby | Boat Design | 6 | 05-11-2007 10:22 PM |
| Attaching Flooring frame to Rib Frame. | jeff goldberg | Boat Design | 0 | 05-24-2006 02:34 PM |
| ChrisCraft Windshield | atlantico | Powerboats | 3 | 03-27-2006 12:13 PM |
| Windshield fabrication | nalbercj | Boatbuilding | 0 | 06-29-2005 10:23 AM |
