Old 10-07-2002, 02:01 PM
Who makes/sells aluminum seacocks/valves
I am looking for a company that makes/sells aluminum seacocks/valves.
Old 10-07-2002, 03:13 PM
Why do you not want a typical bronze seacock? Corrioson?
Have you considered a reinforced nylon / Marelon seacock?
Old 10-09-2002, 08:04 PM
sailvayu sailvayu is offline
Rep: 10 Posts: 19
I have yet to see an alum. valve. If you use bronze you have to COMPLETLY insulate it from the alum. I would go with the plastic.
Old 10-12-2002, 04:17 AM
Metal Cocks
We have to use metal for MCA, especialy in the engine room.
Old 10-15-2002, 09:10 PM
better late then never, try PBM valves in the Pittsburgh Pa. area, they use to make Alum 3 piece industrail ball valves, not sure if they still do
Old 11-02-2002, 04:50 PM
Rep: 1397 Posts: 7,216
You don't need to insulate the seacock from the hull if there is proper anodic protection. Outdrives and outboards.have aluminum housings and the trim cylinders, pivot pins, shafts and other parts are stainless. They have no corrosion problems with proper care and mainteinance. It is mandatory to have metal valves bellow the waterline.
Bonding Aluminum with Epoxy Chris Krumm Materials 49 02-10-2012 05:16 AM
Welders ?!? (Aluminum) DHN Boatbuilding 89 07-20-2009 09:37 PM
installing aluminum gunwale lumie Metal Boat Building 1 09-07-2005 10:20 AM
Aluminum dinghy/life raft... bobola Boat Design 3 07-29-2005 09:04 AM
Structural Foam for Aluminum Hulls jprev Metal Boat Building 3 08-30-2004 09:51 PM
