#46
#47
| Looking forward to seeing the photos, it is aways nice to see someones project. Good luck with it and enjoy working on it. |
#48
| i built this boat using home depot birch ply , epoxy, 8 oz cloth.. painted with home depot concrete floor paint... was a fun build... will it last forever...nope...but if i get another 4 years out of it i will be happy... http://www.boatdesign.net/gallery/sh...6/ppuser/22042 cheers tug |
#49
| I was in a hurry to build a little barge for a project. So I built a square flat dingy out HD luan. It was a simple boat a 8x4x2 box with a 45 degree piece in front to help forward movement. Frame was made from 1x1 nailed together then ply attached to frame. the whole thing was reinforced with glass inside out and then covered with epoxy. I used boat to carry 20 bags of concrete for certain project I had, 2 foot side walls, and motored it from job to job with 5hp. It would actually almost plane with only one person on board. Water eventually got inside into ply and caused it go go bad but fiberglass and epoxy held up. Used it for 3 years, but was almost impossible to get out of water after 1 year. I sunk it at end of 2 year and raised it for use again for 3 year. It worked another year after proper pressure cleaning. Next time I build something like that I will skip the wood. |
| Home Depot have 3/8 foam panels I can use? | souljour2000 | Materials | 2 | 01-21-2010 10:45 AM |
| Working with large fiberglass sheets?? | erikhaha | Fiberglass and Composite Boat Building | 6 | 08-03-2008 01:10 PM |
| fiberglass over white cedar workboat | old man | Fiberglass and Composite Boat Building | 5 | 11-15-2006 03:15 PM |
| 3/4" sheets 4lb-6lb White PU or PVC Foam | pelagiko | Boat Design | 1 | 07-24-2006 09:27 PM |
| Building my first boat from home depot. maybe? | bobbyzahn | Fiberglass and Composite Boat Building | 7 | 05-27-2006 12:48 PM |
