Old 12-20-2008, 09:10 AM
naturewaterboy naturewaterboy is offline
Steel Drum Tuner
Rep: 10 Posts: 210
where to find fuel fill brass elbows
I need to turn my 1.5 inch fuel fill hoses 90 degrees to get from my tanks to my fuel deck fills. Where can I find a brass 90 degree large radius sweep - something like a 4 inch or larger radius?
Wherever you go, there you are...
Old 12-21-2008, 05:12 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,144
I've searched real hard but found no marine suppliers for such products. But I found a suitable alternative: for plumbing and central heating installation there are copper and brass elbows that are normally soldered to copper tubes.
I knew they existed in smaller sizes because I've used them in the past to do some plumbing at home, but for larger buildings they also exist in diameters up to 63 mm (2,5"). And the price is just a fraction of what you'd pay if they were intended for marine use.
Old 12-21-2008, 08:26 AM
Steel Drum Tuner
Rep: 10 Posts: 210
Thanks, CDK. They are available from a plumbing supply house then? Do you know of a source on line?
Old 12-21-2008, 12:30 PM
CDK's Avatar
CDK CDK is offline
No online sources I think. These guys know how to handle a torch and a pipe cutter but faint at the thought of touching a keyboard.
But I'm confident you'll find a local source.
Old 12-21-2008, 09:27 PM
Steel Drum Tuner
Rep: 10 Posts: 210
Thanks, I'll try our local plumbing supply.
Position to fill in UK. kitto Services & Employment 0 03-17-2008 06:22 AM
To High Fill Or Not? Harry Kosta Metal Boat Building 2 02-14-2008 05:25 AM
Silicone exhaust elbows? tuantom Powerboats 3 08-22-2007 08:32 PM
Problem to install Fuel fill and vent jfblouin Boat Design 1 10-17-2006 05:50 AM
Fuel fill system design Deane Henderson Boat Design 6 09-17-2004 07:26 PM
