Old 06-27-2011, 11:32 PM
vaporvette's Avatar
vaporvette vaporvette is offline
Rep: 15 Posts: 29
Where can I find this rub rail?
I am restoring a boat built in 1983 and would like to replace the rub rail but I have no clue where to find one. It is a simple piece that wraps around the seams evenly,held in by rivets. Also,is this a preformed piece or will I be able to make the curves around the bow with a straight piece of rubber? thanks.
(I posted this in two categories because I wasn't sure where to put it.I will delete the inappropriate thread.)
Old 06-27-2011, 11:53 PM
Rep: 3125 Posts: 9,395
There are many types and materials used. Yours looks to be extruded PVC, though I can't tell if it has an insert.
Try (> http://www.tacomarine.com/cat--Rub-Rail--rubrail.html <)
Old 06-28-2011, 12:23 AM
vaporvette's Avatar
Rep: 15 Posts: 29
It's just a simple molded piece.It looks like this "c"
I didn't see one like mine at taco
Old 06-28-2011, 05:00 AM
Call them up and see if your boat is something they have a die for. It's an uncommon boat and not likely listed on their profile guide, but they might know of something that is suitable.
where can I find this rub rail? vaporvette Materials 3 06-28-2011 09:14 PM
Making a rub rail WesS Boatbuilding 13 02-07-2010 11:54 AM
rub rail toolsinbox Fiberglass and Composite Boat Building 8 01-23-2010 06:39 AM
Painting under rub rail? mtnrat Fiberglass and Composite Boat Building 0 06-09-2007 09:34 AM
rub rail replacement prettygoodguy11 Sailboats 1 09-23-2005 07:56 PM
