Old 08-20-2009, 12:42 AM
nwwayoflife nwwayoflife is offline
Rep: 10 Posts: 2
What to use to coat a foam plug?
I just finished shaping a foam plug (a combination of bead board, rigid insulation, and Great Stuff), then filled the surface with typical wall spackle. After some sanding and wet rag here and there, it's at the shape I want. Ultimately I need to pull a fiberglass part off it. What is the simplest thing I can coat the spackle with before waxing to ensure the part will release? Will a couple coats of varnish work, or some type of paint? Ultimately, I'll be using epoxy resin on the cloth. Thanks!
Old 08-20-2009, 03:43 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 513 Posts: 940
I used to coat "quicky" molds with shellac & then use wet & dry paper with wax then polish up a bit. All the best from Jeff.PS: You might wanna sponge on or spray some PVA release agent too.
Old 08-20-2009, 03:52 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,145
PVE liquid release agent works quite good. It is important that the surface is absolutely 100% covered, so one layer is not enough. Otherwise the styrene in the resin will find the tiniest hole and eats your foam.
Old 08-20-2009, 04:34 AM
waikikin's Avatar
Rep: 513 Posts: 940
CDK makes a good point about styrene attacking the foam you've used, you might wanna check its resistance to alcahol too as the shellac & PVA have both got it, if the whole surface is "spackle" you'll probly be ok & you've mentioned laminating in epoxy which is ok with that foam. All the best in your endeavours from Jeff.
Old 08-20-2009, 01:25 PM
apex1
Hello Cornelis and Jeff!!! There is no styrene in epoxy................
Old 08-20-2009, 09:33 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
What is PVE liquid release agent ? I tried to google for it...
Regards
Fanie
Water ! Just gimme water !
Old 08-20-2009, 10:01 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 338
apex is right, no styrene in epoxy. Easy to get too.
Not PVE its PVA.
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 08-20-2009, 11:21 PM
Previous Member
Rep: 0 Posts: 0
If it is not a complex part you can wrap it tightly in polyethylene plastic. Then with heat gun shrink it down. Takes some practice to apply the heat with a heat gun so the plastic shrinks neatly without ripples. It will release without any other coating. Even if the plastic is damaged it is an easy job to recover for the next job. Plastic will also take out minor surface defects in the plug. Use duct tape to secure the plastic to the plug.
I have also used duct tape to completely cover a small plug. It releases OK if the edges are stuck firmly so resin does not get under it.
Rick W
Old 08-20-2009, 11:33 PM
Rep: 10 Posts: 2
Thanks for the answers, guys. I'll let you all know what I end up going with and how it works! Cheers!
Old 08-21-2009, 12:23 AM
mark775
If you spray PVA (polyvinyl alcohol - NOT POLYVINYL ACETATE) Just mist a coat, let dry, complete, or it will fisheye.
Old 08-21-2009, 03:48 AM
CDK's Avatar
CDK CDK is offline
Of course there isn't, but only now I see he wrote epoxy resin.
And of course it is PVA, not PVE.
The ongoing heatwave and too much Weizenbier can do that to you.
Old 08-21-2009, 05:24 AM
waikikin's Avatar
Rep: 513 Posts: 940
Thanks for the advice Apex1, the original post mentions molding a part in epoxy cloth, of course the choices of making the tool off the plug is open to styrenated products or epoxy.
Nwwayoflife, as many paints/coatings contain solvents that will "fry" or dissolve some foams, its good to be carefull in checking on some offcuts the compatibility of materials as results could be dissapointing if it goes wrong. When you say "bead board" I'm assuming that its expanded polystyrene sheet, often called EPS in board making. Regards & all success to you in your molding endeavours from Jeff.
Foam/Plywood boat plug construction ?s cla17 Boatbuilding 22 05-21-2005 03:44 AM
plug howard Materials 0 03-23-2004 02:22 AM
Plug material bevan Materials 3 03-03-2004 10:03 AM
Foam / Plywood Boat Plug Construction ?s cla17 Materials 2 05-18-2003 07:45 PM
Seal coat on PVC foam Materials 2 01-16-2003 09:46 AM
