| What type of varnish? The plans for the wooden boat I am building call for the rails, daggerboard trunk, and keel to have their mating surfaces be sealed with varnish before applying bedding compound for their final attachment. I would assume that this is to make these items more easily released from the bedding compound when they are replaced in the future. Question: Will any varnish work for this or should I use special(expensive) marine varnish? Two of these parts will be below the waterline. The boat however will not be in the water when not in use. Thanks!!! flydog |
| Many older sets of plans called for varnish on mating surfaces to seal the wood. It serves as additional protection against moisture. These are areas that will receive very limited inspection, cleaning and care. A quart can of a good spar varnish will likely do all of these surfaces on your boat, with three coats a minimum. There are other methods, most more costly then using varnish. |
| Thanks PAR! |
| Urethane vs Varnish | MarcD | Wooden Boat Building and Restoration | 16 | 01-16-2012 12:37 AM |
| 64 Resorter varnish help please | H2Only | Wooden Boat Building and Restoration | 25 | 12-22-2006 01:20 AM |
| fiberglass over varnish | fiberglass jack | Fiberglass and Composite Boat Building | 3 | 10-12-2006 07:25 PM |
| Finish varnish coat | DavidJ | Wooden Boat Building and Restoration | 0 | 06-20-2004 09:38 PM |
| Spar Varnish | dcoop | Materials | 4 | 03-22-2003 12:37 PM |
