Old 06-25-2006, 08:28 PM
MONJI MONJI is offline
Rep: 9 Posts: 24
What could be an alternative construction of this yacht?
I've got a 7.8 trailer yacht.
Hull/Deck construction method is 12mm strip planked cedar
and double bios 400gm/m2 (45' Glass)
What consturction(s) could be used for this yacht as alternative?
It would be much appreciated, if somebody can help me out!
Thank you : )
Have a good day !
Old 06-25-2006, 08:44 PM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
There are several methods you could use to build this boat. Many of these methods will not require displacement adjustments to account for weight, others may. There are several fiberglass techniques that could be used, several wooden methods and a few in metal. Since there are a couple dozen different ways to build, have you a method of interest? Keeping in mind, a major deviation from the construction method out lined in the plans, usually means you also need to redesign the structural pieces as well as the hull and deck. The result is a new boat that looks just like the original. Most designs have alternative building methods. Have you contacted the designer?
Old 06-26-2006, 06:24 AM
Rep: 9 Posts: 24
its just for learning purpose. this task's been given by lecturer and the design has been given as well.
Another question
: What are te structural members of construction?
it means like temporary frames?
Old 06-27-2006, 01:01 AM
Rep: 1397 Posts: 7,216
Are you using any scantling rules? These are a set of formulas that give you all the information you are asking for. Gerr has a failry easy to follow system.
Old 06-27-2006, 01:20 AM
Rep: 46 Posts: 173
I would double the comment for Geer's book "Elements of Boat Strength" as a good way to get an idea of the scantlings rules that can work for the most common building methods.
There are many ways to construct a boat. Each material can have several different engineering methods involved in a particular design. All building materials need considerations for their strengths and weaknesses. This means a carvel planked wooden hull will require substantial internal framing, where a strip planked boat considerably less. Even though both are wooden construction, the methods are very different.
The structural members of a boat vary from method to method and from material to material. Some boats have bent frames, others sawn, others none at all. Most boats have a keel, but some do not. The specifics of these are method and material dependant, designed into the structure, based on anticipated loads.
Old 07-03-2006, 01:16 AM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
I like aluminium. For a one-of yacht, you can't really go wrong. As far as thge scantlings go, you could work out the scantlings on the boat you have, and convert them to alum EI=EI making sure to calculate the hull as a complete section first.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Origami steel yacht construction origamiboats Metal Boat Building 1051 09-17-2010 04:23 AM
Naval Architect (experienced in yacht design & construction) Looking for a Position burak.acar Services & Employment 0 06-05-2006 04:10 PM
Looking for books about yacht design and construction flipper Education 17 12-28-2005 11:20 AM
MEGA YACHT DESIGN & CONSTRUCTION Daniel Fenton Services & Employment 0 03-21-2005 11:20 PM
International HISW Symposium Yacht Design and Construction brian eiland Boat Design 1 07-17-2004 09:28 AM
