| What circular saw blade for plywood? I’m using 6mm exterior WBP ply on my project, but the ply chips badly with my standard circular saw (hand model, not a table saw). Looking through my wholesalers catalogue, I see a huge range of alternative blades ranging from 18 to 80 tooth. What would be most suitable for my project? Your help, as always, is greatly appreciated. |
| hello It has been my expierence that a fine tooth blade is best for plywood. The 80 tooth option sounds fine. Good luck. |
| Score your cut line with a sharp knife or cut from back face without too much blade protruding. |
| Handy advice, thanks fellas! |
| Roly is right a rule of thumb is to let only the carbide tooth protrude through the work no more, you will be fine.
__________________ Slippery when wet. www.cheetahcat.com |
| Many, many teeth. And marginal depth (which doesn't track as well, so a straight edge would help). In addition, if you really want a perfect cut, and you own a router, get a bearing-piloted flush-cutting bit and first cut with the skilsaw to a sixteenth from the line. Then clamp a hardwood straightedge to the wood ON the line, and use the hardwood board as a guide to produce a super-square, super-straight finish cut. I used to use this meathod to build cabinet faces before I got a joiner. It's very accurate and controllable. alan |
| 4 blade vs 3 blade | Wellcraft GS | Inboards | 7 | 04-15-2007 09:11 AM |
| 3 Or 4 Blade Propeller? | lifetime | Props | 9 | 05-06-2005 04:22 PM |
| 3 Or 4 Blade Propeller? | lifetime | Materials | 2 | 05-02-2005 04:11 AM |
| 2 Blade Hyde Feathering prop | FAST FRED | Marketplace | 0 | 12-10-2004 05:28 AM |
| blade thickness | andy123 | Boat Design | 1 | 01-29-2004 08:42 AM |
