Old 01-05-2011, 05:31 AM
ecflyer ecflyer is offline
Rep: 72 Posts: 76
What chemical removes cured 3M-5200
Does anyone have experience removing 3M-5200 sealant that is fully cured. I need to remove it off my tempered glass and will try a razor blade on the face side; however, I need a chemical to clean the uneven edges of the glass. I cannot use any type mechanical devices as they will damage the tempered glass.
Have a Spiffy G'Day
Earl
Old 01-05-2011, 08:00 AM
keysdisease's Avatar
keysdisease keysdisease is online now
Rep: 205 Posts: 442
Anti-Bond
There is a product called anti-bond which claims to remove 5200. I read a few forum discussions about it and it seems to be effective, but you need to have patience and give it time. I have no personal experience with it.
http://www.bluecoraltowers.com/ACCES...ve-remover.htm
Steve
Old 01-05-2011, 12:19 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
From my experience: dynamite, C-4 or any other explosive.
Rubber/latex gloves also work well.
-Tom
Old 01-05-2011, 01:36 PM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
Heat up the blade of a scraper and give that a try.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 01-05-2011, 02:20 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
3M's advice about removing the stuff (see the MSDS for details) is:
Pour isocyanate decontaminant solution (90% water, 8% concentrated ammonia, 2% detergent) on spill and allow to react for 10 minutes. Or pour water on spill and allow to react for more than 30 minutes. Cover with absorbent material.
It looks like this only works while it's still uncured. Once it's set, a sharp knife is the best bet. If you can find a solvent that attacks urethane polymers but not glass, that might work.
Without knowing who makes "Anti-Bond" or what chemistry it's based on, I can't offer much other than to say you may as well try it.
Old 01-05-2011, 02:38 PM
mark775
Heat kills 5200 but I don't know about heating that glass. The advice 3M gave about removing uncured works not as well as denatured alcohol -5200 cleans up like school glue with alcohol before it is cured. The anti-bond has to get under the 5200.
Old 01-05-2011, 02:44 PM
kaamaman kaamaman is offline
Rep: 29 Posts: 15
West Marine has this.
http://www.westmarine.com/webapp/wcs...4804&langId=-1
Old 01-05-2011, 03:13 PM
Rep: 72 Posts: 76
Thanks for all the advice
Submarine Tom, I just don't know what we would all do w/o your words of wisdom. You might be a bull in a china shop, but you definitely know how to "Git-R-Done".
Old 01-05-2011, 03:16 PM
Mariner
Sorry ecflyer, I didn't read your post very well.
A razor scraper should do it.
-Tom
Old 01-05-2011, 10:09 PM
Rep: 3125 Posts: 9,395
I've removed it hundreds of times and it has to be abated. A belt sander is quite effective with 24 grit. Chemicals just soften it up, a knife leaves a film. The only real way to insure it's not there is to grind it off.
Old 01-06-2011, 02:26 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1416 Posts: 2,251
I concur with PAR.
Remove as much as possible mechanically, then apply a strong alkaline solution like paint stripper or sink cleaner to soften up the residual film and remove that with a Brillo pad.
Wear gloves!
Old 01-07-2011, 03:20 AM
Typhoon Typhoon is offline
Rep: 150 Posts: 125
I used one of those nylon abrasive wheels to remove some Sikaflex once, it was quite effective. You know the wheels, look like sort of a hard sea sponge. It tended to rip small chunks off the Sika without heating it and making that horrible, acrid blue smoke. And all you had to clean up was a black dust.
Old 01-07-2011, 04:40 AM
CDK's Avatar
CDK CDK is offline
retired engineer
I think you mean 3M Schotch-brite . Is that correct?
Old 01-07-2011, 06:49 AM
indianbayjoe indianbayjoe is offline
Rep: 53 Posts: 108
Don't use any of the chemical ideas if you still want the area to continue to be sealed which was what it was probably put there for. They will seep into areas you don't want them. Mechanical means are the best and you won't scratch the tempered glass with a razor and those rubber wheels made to remove decals might work too. I think there called an astro wheel
Joe
Old 01-07-2011, 09:41 PM
Rep: 150 Posts: 125
Hey, you're right! I didn't pay attention to the manufacturer's name when I bought them. However, knowing me, I bought some cheap, generic version of these wheels:
5200 bottom rideaubill Wooden Boat Building and Restoration 23 11-11-2010 04:34 PM
3m 5200 WickedGood Materials 3 05-21-2010 11:36 PM
chemical removal of yellowing white gel ? pescaloco Materials 32 09-11-2009 12:42 AM
PreKote From Pantheon CHemical; Anyone tried it yet? Jimbo1490 Open Discussion: All Things Boats & Boating 13 09-15-2008 10:39 PM
3m 5200 kudu Materials 10 03-06-2004 12:07 AM
