Old 05-25-2010, 05:06 PM
dskira dskira is offline
Rep: 1305 Posts: 1,372
What is the best antifouling you know
It is a raging war on advertising about antifouling.
Every manufacturer say that it is the ultimate.
Some say it's EPA aprouve, other say EPA is not involve, some say tin is prohibited, and an other one sell with tin based.
Some say 67% cooper, but you can choose your color
The only thing they agree is the price. Prohibitive.
So do you have first hand experience on one brand you like?
Do not matter the hull material, any material, beside aluminum, can be prep for all the antifouling, if the adverstising is right. Of course
Thanks
Daniel
Old 05-25-2010, 11:06 PM
apex1
Hempel....
Old 05-26-2010, 03:11 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1416 Posts: 2,251
"What is the best antifouling you know":
I'm incline to answer that with lead/antimony or arsenic based, all very poisonous and banned. An interesting chili-pepper paint was discussed on this forum but you'd have to make it yourself because it's not on the market.
If the question would have been "the best antifouling available" I'd say Hempel Copperpaint. Not overly expensive, effective against shell building marine life during the next two or three seasons.
Old 05-26-2010, 05:25 AM
yipster's Avatar
yipster yipster is online now
Rep: 1083 Posts: 3,337
we cant generalise like that, there is hard and soft antifoul etc
http://www.marinepainting.net/anti-f...tom-paint.html
Old 05-26-2010, 05:59 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
A trailer.
Hey, it works- I've spent a total of maybe an hour in the last eight years scrubbing marine growth from my hull, and virtually all of that was waterline scum.
Oh, you want PAINT.....
Old 05-26-2010, 08:53 PM
jonr jonr is offline
Rep: 34 Posts: 246
Possibly solid metal:
http://www.p2pays.org/ref/01/00534.pdf
Old 05-26-2010, 09:39 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
we are getting 2 years in tropics from Altex ABC I think they work with Devoe of USA, so Altex is in NZ and here Devoe may call it something else But for 23 years I have used it on all mine
using Zeca system primer over the alloy then the high build then the antifoul(copper base) 2 years in tropics is very good, just dont scimp tho
Old 05-26-2010, 09:52 PM
mark775
"just dont scimp tho" - especially on the primer/insulator! - No problems with the copper on the older ones? I wud have thot that even the proximity to copper wud be detrimental...
Old 05-26-2010, 10:01 PM
Previous Member
Rep: 0 Posts: 0
Mark the Zeca system ddi not come in until later abt mid 90,s I am not sure,
so iIonly did the last (Nimbus) with that, beauty of it is you can damage the paint and the copper is still isolated, the zeca, zinc rich, but it changed the superyacht industry, you know 130 footers hauled every 6 months, very costly
you would need to search it, but basically after the acid wash, you throw on 60 microns DFT then the high build then when the high build is still soft the Antifoul
http://www.altexcoatings.co.nz/technical_resources
Zeca Primer
Immersion Primer for Aluminium Hulls &Copper Antifouling Systems
Availability: Australia, New Zealand
Download: Zeca Primer Datasheet
Old 05-26-2010, 10:12 PM
Previous Member
Rep: 0 Posts: 0
here you are. saved the industry squillions,
i usually take what altex says with grain salt when it comes to prep, they have different story every 5 mins, so ALL the builder I know including alloy yachts int, sand up with 36 grit, acid and Zeca Sandblasting is pretty much impossible these days, even wet and I can see no advantage,
Nimus is 10 now, trouble at all under water
Old 05-27-2010, 12:52 AM
mark775
No more E-paint, then!
Old 05-27-2010, 06:25 AM
Originally Posted by jonr View Post
Interesting arcticle.
Daniel
Old 05-27-2010, 06:30 AM
Originally Posted by apex1 View Post
Hempel....
It was the brand I used for everything in Spain. A very good paint.
But that was long time ago. Before regulations kick in.
I should re-try them to see of the difference.
Not that easy to find here.
Daniel
Old 05-27-2010, 07:04 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
I'll go the Altex/Devoe range, best epoxies and antifouls that I am aware of.
Personally used them for over 25 years commercially.
Old 06-10-2010, 09:58 AM
WickedGood
Lots Of Coppa
Daniel
I have used this Glouster Bottom Paint with pretty good sucess on a boat theat I kept in Glouster Harbor. The boat was used about 3-5 days a week and the paint ould go 2 years without repainting. Knot Bad for the money
Self made Copper-Epoxy-mix as Antifouling? - And the 'same' ready made products? Angélique Materials 50 03-22-2012 05:10 AM
Sandblasting antifouling simon Fiberglass and Composite Boat Building 17 12-24-2009 03:39 AM
antifouling questions? boonbeest Open Discussion: All Things Boats & Boating 1 09-17-2008 05:06 PM
Antifouling propellers Clipper Materials 5 06-22-2007 06:37 PM
Antifouling application alpamis34 Boatbuilding 6 01-27-2007 10:12 AM
