  #31
Old 09-28-2010, 08:53 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Originally Posted by MikeJohns View Post
What about the boats with the powdered copper or copper nickle and epoxy? I have heard of boats that have had the system for 10 years and just need to scrub it occasionally. It's similar in effect to sheathing.
I've heard some good things about this too- epoxy thickened with copper powder. Very labour intensive to apply, from what I've heard. I'd be curious to see how it compares side-by-side with conventional paints.
Another low fouling bottom that seems to work in vessels that go fast enough to self clean is a low energy surface. Teflon and high density polythene. The problem is getting it to stick reliably. If you could adhere thin sheets to an epoxy coated surface with a molecular bond it's suggested that many vessels could use it instead of chemicals .
Interlux claims they can get it to stick- look up Intersleek 970. Epoxy primer, mystery tie coat that is claimed to accomplish this molecular-level bonding, and low surface energy fluropolymer finish. It's not antifouling (no biocide) but it supposedly makes it damned hard for anything to grip well enough to hold on at more than a few knots.
  #32
Old 09-29-2010, 07:58 PM
Rep: 1729 Posts: 2,459
Matt
I thought Intersleek was basically a silicon coating, I know it's been applied to bulk carriers quite successfully. But at paint film thicknesses and being relatively soft it might not be very scrubbable which seems to be required for 'lazy' leisure vessels after a few months.
Mike Johns.
Self made Copper-Epoxy-mix as Antifouling? - And the 'same' ready made products? Angélique Materials 50 03-22-2012 05:10 AM
Sandblasting antifouling simon Fiberglass and Composite Boat Building 17 12-24-2009 03:39 AM
antifouling questions? boonbeest Open Discussion: All Things Boats & Boating 1 09-17-2008 05:06 PM
Antifouling propellers Clipper Materials 5 06-22-2007 06:37 PM
Antifouling application alpamis34 Boatbuilding 6 01-27-2007 10:12 AM
