| welding on negative pressure I was having a hard time getting an airtight hull trully airtight when I discovered that hooking vacume to the hull while zapping a small but persistant leak is very effective. Just wondering if anyone is currently using this method? |
| The reverse method is more common - apply the exhaust of your vacuum to the hull to build Some pressure, but without blowing things out, apply soapy water to the outside in search for the leaking holes. |
| do you know how to press test? when we get survey we always use manometer, which is simply a loop of clear tube half filled water, put 2psi in tank, and watch water go up in the second half of loop, should rise to 8 feet head, ok, then leave it settle, on cold day water will drop and hot will rise, but water should stay there, if drops and drops and drops , hey your tank it not tight, dont forget valves on the tank or water may get into it for yachts in survey, same way they test a liferaft!! no good just testing soap and water, this will find the big leaks, only manometer will be a true test no charge for this info |
| Negative Bows ? | Canada Bob | Boat Design | 23 | 04-27-2009 02:06 PM |
| negative drag in flex gliding gull? | lunatic | Boat Design | 0 | 06-06-2008 11:05 PM |
| Open Discussion – Negative Framing | Sean Herron | Boat Design | 6 | 11-18-2007 07:40 PM |
| mold insert to deal with negative return corners?? | Pavook | Fiberglass and Composite Boat Building | 4 | 11-28-2005 01:10 PM |
| Why not give hulls 'negative camber' on a cat? | Ward | Sailboats | 8 | 06-14-2003 04:19 AM |
