Old 02-21-2017, 10:31 PM
Adarsh Edakkote Adarsh Edakkote is offline
Rep: 10 Posts: 19
Welding of 60mm thk plate
Hi All,
Bending of 120 mm plate with a radius 235 mm is not possible in our area?(No facilities.)So We have planned to bend 2 60 mm thk plate and weld it together.
But How we will ensure the weld strength?or how to prove welded plate has same strength?
please suggest some method to prove it or some calculation reference?
Old 02-22-2017, 12:35 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 2488 Posts: 5,194
You need a minimum bend radius of 4t, so 120 x 4 = 480mm.
If you bend 60 , this is 60 x 4 = 240mm, this is on the limit of acceptability.
However once welded, what is the function of the radius, what loads must it carry and transmit? This shall determine your weld prep and if it is possible to achieve the desired strength requirements. .
Old 02-22-2017, 12:39 AM
Rep: 10 Posts: 19
Thanks for you reply Ad Hoc.
Replacing a heavy solid AL plate OB mounting plate with something lighter? Judy Blumhorst Materials 26 01-13-2017
04:40 PM
thick aluminum plate welding guide Brian.Lin Metal Boat Building 1 04-27-2016
01:46 AM
Welding Sequance Katoh Metal Boat Building 18 06-11-2010
08:57 AM
Cutting and welding 2" 5083 plate? monckywrench Metal Boat Building 4 11-09-2007
02:58 PM
welding steel plate on a keel lockd Metal Boat Building 4 11-10-2005
05:50 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
